is there a way to increase the screen's resolution over the maximum capacity of win?
kukuriku14
I have a Samsung SyncMaster 226BW (22" wide) screen and GForce 8400GS screen card. I use Windows Vista x64 OS, is there a way or does someone know a trick I can increase the screen's resolution above 1680*1050 (this is the maximum resolution the OS provides and this is the maximum res. listed by the screen manufacturer as well)?
thanks ppl for your time
Fumz
Buggin
Re: is there a way to increase the screen's resolution over the maximum capacity of w
Your monitor performs best at its native resolution. You can play at resolutions lower than 1680x1050, but not above. However, the picture is still best at native. If by change you make the mistake of setting some game's resolution to more than 1680, you may soon find yourself in safe mode uninstalling drivers... besides, the 8400GS is a low end card that can barely handle 1680.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Dwarf
The Contemplator
Hi kukurik14,
Sorry, but there is no way to increase the screen resolution above the native resolution of your monitor. Vista does cater for larger resolutions, but these are subject to the monitor and graphics card that you use, although the maximum resolution will be limited to the native resolution of your monitor (as stated above). In order to protect the monitor, Vista and the graphics card drivers usually hide the modes that the monitor cannot display, so if you wish you can change this setting to show all modes to see what other resolutions are available. WARNING - IF YOU CHOOSE A SETTING HERE THAT YOUR MONITOR DOES NOT SUPPORT, YOU MIGHT DAMAGE IT. If you are after more screen estate, then you will either have to go for a multi-monitor display setup or invest in a monitor with a larger resolution.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
kukuriku14
you mean damge something in the OS or you're talking about an irreparable physical damage?
mike-cow
Vista Pro
I MAY BE WRONG HERE! But based on the fact that I've NEVER heard of a TFT/LCD monitor breaking because of usupported settings I'm fairly certain that the physical failure problem is a CRT issue.
I'm 100% sure though, that you won't have *any* benefit from trying to trick the monitor into showing more lines. In the unlikely event that you'd actually get it to work it would only look like crap, since some lines wouldn't be displayed because of how flatpanel technology works. If you need to show something of a higher resolution on your monitor, find software that downscales for you (don't know *any* videosoftware that doesn't do that :P).
I'm assuming you're considering the possibility of adding 30 lines vertically to get 1080p resolution. Bear in mind that 1080p is actually 1920x1080 resolution... So it's not as close to the resolution of your monitor as the 1080p label might lead you to believe. :)
    Home made
    AMD Athlon X2 6000+
    ASRock ALiveXfire-eSATA2
    2x2GiB DDR2 PC2-6400
    GeCube ATI Radeon HD3870 512MiB GDDR4
    Built in HD Audio, digital output
    Samsung SyncMaster 206BW, SyncMaster 940B
    1680x1050 + 1280x1024
    WDC 250GB SATA + lots of externals. :)
    Antec Earthwatts 500W
    Antec Sonata III
    Air
    Logitech G9
    Logitech G15 (1st edition w blue lightning)
    DL/UL: 50/10Mbit
Dwarf
The Contemplator
No, I mean that it is possible to damage your monitor by trying to get it to display a resolution that it does not support, especially if you are trying to get it to display a resolution which is higher than its native setting.
Dwarf.
    Gigabyte IF233
kukuriku14
just asked;
I am a software developer and thought I'll have the ability to have smaller icons in the bars, and smaller/visible lines...
thanks for warning me, I really don't want to damage my screen right now...
mike-cow
Vista Pro
Out of curiosity I did a very quick attempt at finding evidence of *any* monitor REALLY breaking because of attempting to use unsupported resolutions... Didn't find anything. I know a *few* people who actually got problems with their CRT monitors because of it, but even that seems *extremely* rare. All I find is people saying "Don't do it, you'll ruin your monitor". :)
    Home made
    AMD Athlon X2 6000+
    Antec Sonata III
    Air
    Logitech G9
    DL/UL: 50/10Mbit
kukuriku14
not only I don't use CRT nor LCD but I use TFT, it really looks strange that you could damage a screen physically with setting higher res.
however,
the resulution I use is listed as maximum res. in the list.
mike-cow
Vista Pro
however, the resulution I use is listed as maximum res. in the list.
You can *easily* tweak that so you can set higher resolutions, but it won't help you, since the monitor will show you a nice "Unsupported Resolution" box and nothing else.
Unless the issue is that your monitor actually is capable of higher resolution, and the info the OS get is incorrect. But that's not the issue here, your 226BW is just not capable of better. :)
    Home made
    AMD Athlon X2 6000+
    Antec Sonata III
    Air
    Logitech G9
    DL/UL: 50/10Mbit
skunksmash
im coming for cake
i think more the worry here is displaying a res above native ...the screen shows a scrambled layout & it wont revert ..
so as stated earlier you may find yourself removing perfectly good drivers
native resolution will give you the best image quality
if you need smaller icons you could try this..:)
http://www.vistax64.com/tutorials/61412-desktop-icon-size.html
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
kukuriku14
OK.
I'll keep being happy with my lot(?)...
thank you all for your help and info...
