ISO File Type Association?
farzadmf
Hi everybody
I have Virtual CD installed on my computer and it was handling .iso files and a very useful feature it had, it caused some options to appear in the context menu of the file (i.e. right clicking on the file) to be able to directly insert the .iso file into a virtual drive.
But then I installed WinRAR and regretfully (!!!) I chose WinRAR to associate with .iso files ... and I lost those useful options in the context menu.
Can anybody help me to have those options again?
Thank you ...
mansrm81
Right click on the iso file and if the program is in the default area pick it if not just click on browse and go where the program is istalled and make sure the box is checked.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
dinesh
Vista Expert
Do a system restore.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Brink
Staff member
mvp
Hello Farzadmf,
You might check the settings in Virtual CD to see if it has an option to check to set it back as that default program for ISO files. Be sure to also unset this in WinRAR. If not, then reinstalling the program to perform a repair install may fix the issue.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
farzadmf
Thanks everybody for your replies, but the problem is that the option(s) I want to be added are not related to the default program associated with .iso files; in fact the option(s) I'm looking for was being displayed in the context menu when I would right-click on the file and this menu, I think, has nothing to do with the default program that double-clicking on the file opens.
