I have tried everything to display file size in the Windows Explorer folders. I am using Vista version 6 SP1.
My folder is set to view 'all items'. It shows me name, date modified and type. When I right click to display column options, I can't locate size. There are a bunch of other column options, but size is not among them. Any help would be appreciated.
Thank you
the problem is simple to fix, however to solve it is not Intuitive --
- open MY COMPUTER File view
- View Details
- Right Click on top of column Headings
- Click on MORE (was more an option? I believe was in more is not available elsewhere and vice a versa)
- Select Headings you want to show/not show
- Apply
This problem happened to me, and drove me a bit crazy till I found out how to solve it.
Why someone told you to repair/scan now etc, did not make a lot of sense. Obviously this was some kind of setting issue.
Kevin
