hi there,
i am trying to boot from one of my Setup Partitions. i am trying to boot from a partition containing Windows Xp 64-bit Install Files and later a partition with Windows 7 Install Files. i have deleted all the Setup Partitions except the Windows Xp one which is being a Bi*ch and won't allow me to delete it.
these are the steps i have done to try and boot
1. Created ISO Image Windows Xp and downloaded Windows 7 build 7100
2. In Disk Management Shrink 2 Volumes on main HDD with OS (Vista) 1 being Setup Files Shrink to 700MB and OS shrink too 7GB
3. Opened cmd and input diskpart, list volume, select volume y (Setup Xp), active, exit, then xcopy... Etc.
when i rebooted i would get a bootmgr missing error and thus using my Windows Vista disc to repair. i have be doing something wrong here as i am still new to this dual booting stuff.
yes, i am trying to triple boot. Vista, Xp and Windows 7. i do know to install Xp first then Windows 7 last or does it matter?
- 1COMP
- AMD Athlon 4850e 2.5GHZ OC'ed @3.1GHZ
- ASRock A780GXE/128
- G.SKILL 4GB (2 x 2GB)
- EVGA 512MB 8600GTS 706/1008MHZ (Stock Defualt)
- Onboard
- 19" ENVISION
- 1440x900
- 320GB [OS] | 160GB [Storage] | 80GB [2nd OS] | 40GB [BAD STATUS]
- PSU
- Rosewill 450W 12v @30 Rails
- Case
- COOLER MASTER Centurion 590
- Cooling
- XIGMATEK HDT-S963 | 5 Blue LED 120mm Fans 1 Regular 120mm FA
- logitech 7100X? don't remember actual Model
- DSL 3MB 370kbps Up/70kbps Down
