iTunes install problem
bogart
My PC locks up when trying to install iTUnes at the point where it is saying to me
"Registering iTunes automation server"
Ive done everything that the iTunes help section has suggested still no luck.
Im using Vista 64 bit.
    Intel Q6600
    Abit IP35 Pro
    4GB crucial
    ATI HD4350
    4 Samsung spinpoints
    Corsair 550w
Are you absolutely sure you are installing the 64 bit version of iTunes and not the 32 bit version?
The 64 bit version can be downloaded from iTunes 9.1.1 for Windows (64 bit) (I admit it's not easy to find).
I hope this fixes you problem.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
Got there in the end appears you have to have SP2 loaded.
Thanks
    Intel Q6600
    Abit IP35 Pro
    4GB crucial
    ATI HD4350
    Corsair 550w
Good, I'm glad the problem's solved.
It's always a good idea to keep your PC completely upto date.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
Not my PC, it's my wifes. So what can one expect:D
    Intel Q6600
    Abit IP35 Pro
    4GB crucial
    ATI HD4350
    Corsair 550w
