Itunes/QT help
Matt H
3
I just got an Iphone and I need to have an updated Itunes/Quicktime. I was told to uninstall then reintall newest version. Each time I try to uninstall, I get a message that reads
"Could not open key HKey_Local_Machine\software\microsoft\windows\software\currentversion\run Verify you have sufficient access to that key or contact administor"
HELP!!!
3,375
Hello, and welcome to the Vista Forums!
Make sure you run the uninstaller with Admin Privileges. If this does not help, or you already are, come back here.
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Matt H
3
Thank you. I did make sure that my user had Admin privileges with full access. I ended up just deleting the "run" with its sub files and that did the trick.
3,375
Hello,
Is everything OK? I certainly would not have recommended that, as that is one of the big startup locations for programs. Some of your startups won't start up, and if you have any other problems, don't hesitate to come back here.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
3,375
OK, well, you are always most welcome to come back to this same thread if you have any problems relating to this, as then you won't have to re-explain anything, and I will not be leaving this forum in the near future.
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
