Java for IE8
29
Location
California
Hi
Trying to use the web without Java is like trying to swim with a anchor.
I have some problems with getting to use pogo games (I've checked their site for help...refer to anchor comment above) and nothing.
I've gone to Java site and same results. I've done a web search and same results.
Here is problem.
I can log into pogo ok and then select game and get the "you need java" msg.
I have java. Version 6 update 16. I have IE8 on a vista 32bit os.
Java says to make sure java is enabled for internet explorer in java control panel.
I go to java control panel, advanced tab, default for java browsers and the entry for microsoft internet explorer is greyed out, but box does show a check mark.
This doesn't seem normal to me. I should beable to check and uncheck that box.
I think that java control panel is not seeing IE8, therefore, nada on the pogo.
see attached screen shot.
Any aid in resolving this issue will forever earn you warm fuzzy feelings.
Thanks
    I built my own
    Intel Core 2 Quad Q6600 2.40GHz 8MB Cache 1066MMHz FSB
    Asus P5N-D NVIDIA nForce 750i SLI Socket 775
    OCZ Dual Channel PC8000 DDR2 1000MHz 8Gigs
    BFG GeForce 8800 GTS OC 512MB GDDR3
    Sound Blaster Audigy
    Hanns.g 28" true 1080p w/hdmi
    1920 x 1200 I use the whole screen
    I use Seagate Barracuda 7200 11 500GB Hard Drives
    OCZ StealthxStream 600 watt/ATX/120mm fan
    Apevia X-Telstar full tower case w/clear side panel
    Cooler Master Sphere CPU cooling fan Copper heatpipe
    Logitech track ball
    Logitech G11
    cable
    I use this computer for the express of Flight Simulator X.
    Nothing has been overclocked (don't know how).
    Always looking to get the most I can out of it's processing power etc to enhance my flight sim experience
29
Location
California
Just a note on what I posted above.
I have two computers. One is 64bit and one is 32bit. My post does refer to the 32bit os.
Thanks
    I built my own
    Logitech track ball
    Logitech G11
    cable
brummyfan
Brummy
731
Location
Birmingham
Hi cuff,
I have found some suggestions here, I do have the same problem as well but I haven't tried any suggestions as I'm tired(Summertime ends tonight) and I'll have a go tomorrow.
IE8 installed now java not working
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
brummyfan
Brummy
731
Location
Birmingham
Methods in my previous post is not working. :(
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
29
Location
California
Hi
Thanks for your reply.
I went ahead and took a look and I did get one thing to happen that had not before.
I logged into pogo, clicked on my favorite game (word whomp), saw the java loading and all I got was "welcome to pogo" log in screen again.
And thats all I could get.
I suppose thats something. At least it wasn't the Opps no java msg again.
Oh well.
Thanks for your help.
Regards
Ernest
    I built my own
    Logitech track ball
    Logitech G11
    cable
brummyfan
Brummy
731
Location
Birmingham
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
29
Location
California
Thanks
Have you been able to log into and play pogo games?
    I built my own
    Logitech track ball
    Logitech G11
    cable
brummyfan
Brummy
731
Location
Birmingham
#8
Sorry mate, I don't play any games.
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
cuff
29
Location
California
#9
Thank you for your help.
    I built my own
    Logitech track ball
    Logitech G11
    cable
