just wondering
fredrick
Using vista about 3 or 4 years ago I got on face book to see someone from years back. They posted a link for some music for me t hear,so I clicked theses links but they played nothing.jokes on me now that they have some inside access to a lot of stuff on my comp. looking back Im sure it was thoses links. I just want to know what that is called ,is it called crossite scripting or dowloads from a site for hackers What all is involved in that process?
Patonb
Depends on the actual infection. Odds are they automatically create a post with a disguise address. Quite simple to do on forums
www.vistax64.com
www.vistax64.com
Try those 2 links..
So the disguised link lead to a d/l and blam, you're tricked.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
fredrick
Thankyou pat, I would assume the trojan that was installed came from a webite,they wouldnt write it most likely. It would be called a script kiddy from what I have read.
Shadowjk
Network Enthusiast
Quite a common exploit. From the server side the damage they could do is huge. As part of my college work I exploited a java vulnerability to perform a similar task. With it I was able to upload a script to the victim machine and execute it. If that was a virus that relies on user interaction I could essentially do it for them.
Tis a cruel world out there! Be careful :geek:
Josh :)
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
