coree4braids
My home computer wants to install 1 of 1 update all the time I can do it 10x a day and it never stops. It says that the update fails and has an error code 80070017. Does anyone know how I can fix this?
Hidding update isn't any solution -surly in future you will have problems with other updates too.If post 2 doesn't solve problem I strong recommend diagnose your hdd by using manufacturer tool Bootable Hard Drive Diagnostics - Voxhow do you set up to notify and not install?
