keyboard shortcut for disabling touch pad
Dwarf
The Contemplator
Hi krugger4779 and welcome to Vista Forums :party:
Can you please let us know the make and model number of your laptop as the key or key combination can vary. Without this information, the best I can suggest is that you check your manual and follow the instructions there.
  • Name
    Guy
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
    Occupation
    Library Caretaker
    Country Flag
    england
    State/Region Flag
    uk yorkshire
krugger4779
I had already scan my pdf manual and I wasn't able to find any solution for my problem. I also tried to examined the settings from my device manager, mouse property settings but I still could not find the solutions.
I hope you could help me here. Thank you.
limneos
Power User
  • Name
    Elias
    Limneos
    Intel Core2Duo E4500 2.2GHz
    Asus P5LD2-X/1333
    2GB 800Mhz Kingston DDR2
    Nvidia 8500GT
    Occupation
    IT Tech/Admin
    Country Flag
    greece
Dwarf
The Contemplator
Hi krugger4779,
This took a bit of finding, but I hope that the information in the following link helps. This is for disabling the touchpad - to reenable it follow the instructions except at Step 5 you need to check the box instead of clearing it.
View Document
  • Name
    Guy
    Gigabyte IF233
    Occupation
    Library Caretaker
    Country Flag
    england
    State/Region Flag
    uk yorkshire
