Keyboard Shortcuts problems
ls12
4
Hi I was wondering if anyone could help me on this problem i hav regarding windows vista. I turned on my laptop and when I go to write something either on Word or the internet, for Eg, the letter L locks my laptop straight away, and C goes to the Control Panel, they seem to be automatic shortcuts, I have no idea how to stop this, i have tried useing the toggle keys, but this does not work for me, does anyone know?
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
Per this MS Bulletin, the window key and L should lock the computer.
Is the window key stuck or do you depress it by accident?
Can you try another keyboard?
Keyboard shortcuts for Windows
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed between now and the restore point, but you can use Windows Update for the updates.
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello ls12, and welcome to Seven Forums.
You might check to see if it may be Sticky Keys that got turned on by mistake for your Windows key. Be sure to uncheck the Turn on Sticky Keys when SHIFT is pressed five times option.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
richc46
Staff member
20,105
Location
And the record, three posts at once.
ls12
4
Hi , This dosnt seem to help either, I have tried this, i dont know what it is,
Lorien
Account Suspended
2,212
Location
Did you try a System Restore?
    1920 x 1200 pixels
    6TO4 Adapter
Lorien
Account Suspended
2,212
Location
#9
Read my first post. It contains an article with the procedures as well as some extra explanations.
    1920 x 1200 pixels
    6TO4 Adapter
