Kodak Easyshare Software Error
buckeye9
I tried to install Kodak EasyShare Sofware Version 8.0 and get error code 1616X17x2103064800x. This error code is not listed in Kodak's FAQ Error Code Table. Anyone know what is causing this problem.
Buckeye9
lemur
Buckeye9
Would you verify you selected the Vista option for the software from this URL ...
EASYSHARE Software Downloads
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
stormy13
Any particular reason for using EasyShare? Unless there is a specific feature of it that you use, it isn't needed on Vista or Windows 7. It isn't needed for drivers or anything else as most if not all Kodak cameras (unless it is really old) should be detected and a driver installed just fine in Vista. Then it just a matter of using Windows own import feature.
I have a couple of older Kodak cameras (CX4230 and a DX6340), and both work just fine in Vista and Windows 7 (both 32 and 64 bit versions of Windows at that) and EasyShare isn't needed (actually haven't used ES in a very long time, as it isn't even needed in XP).
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
