Lag Spikes on WoW
archie123
I Tunes hates Me
erm , fps lag or internet lag? Is it suddenly started happening after running smoothly?
and what are your system specs and what game settings?
how you expect anyone to help out with so little information i have no idea mate :P You put in a bit of effort and we'll put some in in return ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Aaron911
Yes I have the same problem but it's with the fps. For about 10 to 20 minutes it will run smooth about 30 fps, then outta nowhere it will go straight down to 6 to 7 fps which is unplayable conditions. Then I would have to window out for about 2 minutes for it to go back to normal. I don't know if it's Blizzards fault or my lap top but I would love to know how to fix this issue. Thank you.
    HP Special Edition/dv2945se
    285 Gb
    Nvidia
    Cooling Fan Curve
    4g
