Solved Laptop Battery Wont Charge
mrigankp
I am using a HP Laptop, 6314tx. It has been 1 year and 9 months since I am using it. In the past couple of months, I have experienced a battery problem. My laptop battery doesn't charge more than 33%. It was 67% first, then came down to 43% and now 32%. Sometimes, it shows '100% available (plugged in, charging).' But, when I click on the battery icon, it again shows as '32% available (plugged in, charging).'
Is there any solution to this?
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Nvidia GEFORCE GO 7400 128mb
    Hitachi SATA 160gb
    External Seagate 1TB HDD, Logitech 5.1 speakers
Brink
Staff member
mvp
Hello Mrigankp,
You might use this HP battery test to see what the health of your battery is. It may be time to get a new battery or charger. You can read more about this test here.
Hope this helps for now,
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
mrigankp
Hey Brink. Thanks for the link. I downloaded HP Battery Test software. I clicked on the exe file and ran the setup. But, after the setup is complete, I don't see anything on my screen. I also checked in 'programs.' What could be the problem?
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Hitachi SATA 160gb
Brink
Staff member
mvp
Not sure, but this is what they say:
The Battery Check utility can be launched by clicking Start > Control Panel > HP Battery Check or by clicking Start > Hewlett-Packard > HP Battery Check
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
mrigankp
I restarted my computer and the software started working. It says that the battery's health is weak. I need to replace my battery. But, I don't understand one thing, why the does the battery indicator sometimes shows '100% Available, Plugged In, Charging?'
Anyway, thanks for your help.
Cheerz!
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Hitachi SATA 160gb
Brink
Staff member
mvp
It's normal to get fluctuating results like that when the battery is failing. Sometimes it will be just fine, while most of the time it will not be. :(
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
mrigankp
Thank you for your help.
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Hitachi SATA 160gb
Brink
Staff member
mvp
You're welcome Mrigankp. I'm sorry to hear that you battery is in bad health.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
mrigankp
Oh well, it was going to happen sooner or later. I am thinking of buying a 12-cell battery. It is said that it gives a 3.5+ hours on 'high performance.'
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Hitachi SATA 160gb
Brink
Staff member
mvp
That's not bad at all with high performance. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
