laptop display problem
Been working on this doing the usual searches and attempts at fixes.
First the hardware - hp dv9810uS with nVidia gEforce go 7150
The hp bios and graphics drivers are upto date (were reinstalled anyway)
The problem - Wife was using about ywo weeks ago and the display lost all definition.At 1440x900 its thin even spaced vertical lines. Where the color portion crosses text the characters can be random colors. Drop it back to 1024x728 and things are readable.
  • I checked all drivers,ran Malware and rootkit checker just to be sure.
  • Hooked it to my monitor on desktop and all was fine.
  • Ordered and installed new display panel.....no change.
  • While doing that checked connections and wiring
  • Checked power settings but its usually on wall power
  • Windows updates are current
I can usually find and correct problems, keeping two servers,6 desktops and two laptops working.
This one has be stumped. I've searched and searched and closest thing seems to be this series nVidia chip problems , but thats usually a no display problem.
When I drop down the resolution its readable somewhat. oh and playing a movie no difference.
I've also tried tweaking.com repair tool (its helped me out a few times) and advancesystem care all for naught.
I would be most grateful for any and all input before I put a torch to this thing. :devil:
    HP dv9810US
    2.00 GHz AMD Turion 64 X2 Dual-Core
    3gb
    NVIDIA GeForce Go 7150M
    17" WXGA+ High-Definition
Patonb
Hello, Only thing I can think of is the ribbon.
Welcome to the forum.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
roy69
47,65,65,6B
Try booting from linux and change the resolution. If you get the same problem then as has been said look at hardware.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Sorry, left out it is the only Vista machine I have, version is home premium.
By ribbon do you mean the switches across above the keyboard that these have?
Good suggestion on the linux...........I'll put Ubuntu on a disc and boot from that.
Appreciate the input.
    HP dv9810US
    3gb
Patonb
Usually the cable the video card to the actual screen is a thin ribbon cable. I've seen times when the cable kinks or rubs and screws up the screen.
