Laptop Screen Scrambled
TGL
40
Location
USA
For the past 5 days or so, the screen on my laptop gets scrambled after being on for a few hours. What happens is, the taskbar goes to the top of the screen, desktop background becomes black mostly except for the bottom edge, desktop icons appear on top of the windows-nothing overlays properly, all the windows flash all over the place on top of each other, and while it's doing all of this, I can't even click on anything or access task manager by clicking Ctrl-Shift-Esc or Ctrl-Alt-Del so I can end a process. All I can do to get out of this, is, turn my computer off and restart my computer or press the power button to turn off my computer, then right before it turns off, I click the Cancel Button that appears in the middle of the screen that appears showing you what programs you need to close out before shutting down the computer-that's all I can do. After I click the cancel button, everything is straightened out, but the windows have switched back to Windows Vista Basic.
The first time it done this, I restarted my computer, and when it restarted, my computer automatically chose to perform a disc check on its own and it deleted a corrupt file or something like that-I can't remember exactly.
My laptop has never done this before no matter how much I've got going on in my computer, but this is happening even with just one internet explorer window open-it doesn't matter what or how much things I have opened up.
Things I have done to fix this:
1) I've ran a full disk check-the one that goes through all 5 stages.
2) Checked display adapter in device manager-it's working properly.
3) In command prompt-SFC/scannow
    Gateway,M-6324,Laptop
    Intel(R) Pentium(R) Dual CPU T2370 @ 1.73GHz, 1
    Motherboard GM965 Chipset Intel Video W/10/100LAN No HDMI (F
    Memory: 3072MB DDR2 Dual-Channel (1 x 1024MB, 1 x 2048MB)
    Graphics Adapter: Mobile Intel(R) 965 Express Chipset Family
    Generic PnP Monitor
    WDC WD3200BEVT-22ZCT0 (6/21/2006)
    Hard Drive: 320GB HD
ilikefree
2,877
Location
New Zealand
Did sfc /scannow find anything?
Do you have any anti-virus programs installed?
Have you done a malware scan? Malwarebytes
Have you started a disc scan
Go to computer. right click the drive with your operating system on,Tools,
schedule a disc check for next start and include the option to scan and repair bad sections.
Post back your outcome.
Edit: note there is a space before / in sfc /scannow
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
TGL
40
Location
USA
Oh, I forgot to mention that I performed a full virus scan with System Suite 10 and everything was OK. I did perforn the full disc scan and it went through all 5 stages, as I had mentioned above.
Results of disc check performed on 7/30/2010-the computer did this own its own the first time my screen got scrambled after I restarted:
Code:
Log Name: Application
Source: Microsoft-Windows-Wininit
Date: 7/30/2010 6:11:00 PM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: Tonya-PC
Description:
Checking file system on C:
The type of the file system is NTFS.
Volume label is Partition_1.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Attribute record of type 0x80 and instance tag 0x4 is cross linked
starting at 0x2b50 for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x4
in file 0x84030 is already in use.
Deleting corrupt attribute record (128, "")
from file record segment 540720.
579328 file records processed.
4776 large file records processed.
0 bad file records processed.
0 EA records processed.
128 reparse records processed.
Unable to locate the file name attribute of index entry rascfg.dll.mui
of index $I30 with parent 0x862 in file 0x7925.
Deleting index entry rascfg.dll.mui in index $I30 of file 2146.
The multi-sector header signature for VCN 0x0 of index $I30
in file 0x13d51 is incorrect.
4d 5a 90 00 03 00 00 00 04 00 00 00 ff ff 00 00 MZ..............
b8 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 ........@.......
Correcting error in index $I30 for file 81233.
The index bitmap $I30 in file 0x13d51 is incorrect.
The down pointer of current index entry with length 0x18 is invalid.
00 00 00 00 00 00 00 00 18 00 00 00 03 00 00 00 ................
ff ff ff ff ff ff ff ff 4e 6b a3 39 7c fe c6 01 ........Nk.9|...
4e 6b a3 39 7c fe c6 01 0c 5e e7 45 fe 2e c9 01 Nk.9|....^.E....
Sorting index $I30 in file 81233.
674276 index entries processed.
CHKDSK is recovering lost files.
Recovering orphaned file rascfg.dll.mui (31013) into directory file 2146.
Recovering orphaned file MORECO~1.ONE (81281) into directory file 81233.
Recovering orphaned file More Cool Features.one (81281) into directory file 81233.
Recovering orphaned file GETTIN~1.ONE (258864) into directory file 81233.
Recovering orphaned file Getting Started with OneNote.one (258864) into directory file 81233.
4 unindexed files processed.
Recovering orphaned file ONENOT~1.ONE (259158) into directory file 81233.
Recovering orphaned file OneNote Table Of Contents.onetoc2 (259158) into directory file 81233.
579328 security descriptors processed.
Cleaning up 1181 unused index entries from index $SII of file 0x9.
Cleaning up 1181 unused index entries from index $SDH of file 0x9.
Cleaning up 1181 unused security descriptors.
Inserting data attribute into file 540720.
47476 data files processed.
CHKDSK is verifying Usn Journal...
35788592 USN bytes processed.
Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
301122359 KB total disk space.
171742380 KB in 497635 files.
390036 KB in 47476 indexes.
4 KB in bad sectors.
698515 KB in use by the system.
65536 KB occupied by the log file.
128291424 KB available on disk.
4096 bytes in each allocation unit.
75280589 total allocation units on disk.
32072856 allocation units available on disk.
Internal Info:
00 d7 08 00 64 51 08 00 44 0e 0f 00 00 00 00 00 ....dQ..D.......
6e 0f 00 00 80 00 00 00 00 00 00 00 00 00 00 00 n...............
08 1c 0e 00 48 01 0e 00 45 09 00 4c 08 83 0f 00 ....H...E..L....
Windows has finished checking your disk.
Please wait while your computer restarts.
Event Xml:
<Event xmlns="[URL]http://schemas.microsoft.com/win/2004/08/events/event[/URL]">
<System>
<Provider Name="Microsoft-Windows-Wininit" Guid="{206f6dea-d3c5-4d10-bc72-989f03c8b84b}" EventSourceName="Wininit" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-07-30T23:11:00.000Z" />
<EventRecordID>98098</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Tonya-PC</Computer>
<Security />
</System>
<EventData>
<Data>
[B][U]Also[/U][/B]-Disk Check Results on 7/31/2010-disc check was performed by me this time:
Date: 7/31/2010 8:35:44 PM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: Tonya-PC
Description:
A disk check has been scheduled.
4790 large file records processed.
674280 index entries processed.
1 unindexed files processed.
Cleaning up 17 unused index entries from index $SII of file 0x9.
Cleaning up 17 unused index entries from index $SDH of file 0x9.
Cleaning up 17 unused security descriptors.
47477 data files processed.
35811256 USN bytes processed.
CHKDSK is verifying file data (stage 4 of 5)...
579312 files processed.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
32735044 free clusters processed.
Free space verification is complete.
169093232 KB in 499331 files.
390424 KB in 47478 indexes.
698523 KB in use by the system.
130940176 KB available on disk.
32735044 allocation units available on disk.
Internal Info:
00 d7 08 00 05 58 08 00 9e 1b 0f 00 00 00 00 00 .....X..........
6f 0f 00 00 80 00 00 00 00 00 00 00 00 00 00 00 o...............
42 00 00 00 12 75 38 77 f0 85 30 00 f0 7d 30 00 B....u8w..0..}0.
Event Xml:
<System>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2010-08-01T01:35:44.000Z" />
<EventRecordID>98248</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>
[B][U]Also[/U][/B]-SFC/scannow results-I just did this:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>SFC/scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some of th
em.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
C:\Windows\Logs\CBS\CBS.log
This might be easier to read:
View attachment 2 Disk Check Results and 1 Scannow Results, Document.doc
    Generic PnP Monitor
ilikefree
2,877
Location
New Zealand
There are people here that will want to see your CBS.Log.
Type this into start search box
%windir%\Logs\CBS
Copy it to your desktop,zip it up and post back.
    LENOVO 64734VM
    15 inch
    External Speakers
TGL
40
Location
USA
%windir%\Logs\CBS
I copied it to my documents, zipped it, and tried to upload it and I got the message, "Upload of file failed". Is there something else I need to know about uploading zipped files?
    Generic PnP Monitor
ilikefree
2,877
Location
New Zealand
    LENOVO 64734VM
    15 inch
    External Speakers
TGL
40
Location
USA
http://www.vistax64.com/vista-general/82943-re-sfc-cannot-fix-errors.html
I Found this thread for you. It explains how to strip out the stuff that is not needed.
That will make it smaller and should go through.
I was able to zip it, but it just will not upload-it's only 2.02 MBs. Anyway, I've uploaded it to SkyDrive and I'm going to provide the link to (My Zipped CBS log from SkyDrive below):
http://cid-5ab11ae60cf3e7b7.office.live.com/browse.aspx/CBS%20Zip
Tell me if you can download it from there.
Thanks
    Generic PnP Monitor
ilikefree
2,877
Location
New Zealand
#8
Can see it there but not download it.
In your post you should be able to click on the paper clip,browse, Highlight the file and click enter,
upload.
wait until it says done and close the box.
    LENOVO 64734VM
    15 inch
    External Speakers
richc46
Staff member
20,105
Location
Fairfield County, CT
#9
ilikefree
2,877
Location
New Zealand
#10
The sfc check did fix some of the errors. I would run it again
    LENOVO 64734VM
    15 inch
    External Speakers
TGL
40
Location
USA
#11
upload.
I tried it again and waited and I still get the message, "Upload of file failed."
I did change the link to the Zipped CBS Log-SkyDrive in my post above. See if it works again. Did you double click and then double click again? Then, there should be a little window that asks you whether you want to open or save it. I've got it set to where it is shared with "Everyone". Although, I admit, this is the first time I have done this.
Thanks
Nevermind, it looks like you were able to view it. I was a few minutes late when posting this. I'll try running SFC/ scannow again, but it has always said that it has found corrupt files and was unable to fix some of them. And, I always follow up with a full 5 stage disk check, but those corrupt files never get completely fixed because when I run SFC/ scannow afterwards, it says the same thing again.
    Generic PnP Monitor
TGL
40
Location
USA
#12
    Generic PnP Monitor
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
#13
I agree. Sometimes you need to run this tool several times in order for it to fix everything (or what it is able to). This is because there might be multiple errors, the correction of which depends on the correction other errors.
@John/Shawn: I tried to upload the .zip file here, but got the same upload failed message. At 2.2MB, it is well within the 10.0MB file size limit.
I have reported this issue.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
TGL
40
Location
USA
#14
    Generic PnP Monitor
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
#15
    Gigabyte IF233
ilikefree
2,877
Location
New Zealand
#16
    LENOVO 64734VM
    15 inch
    External Speakers
ilikefree
2,877
Location
New Zealand
#17
Not sure which of your anti-virus programs is fake, but it looks like System Suite 10 is fake. Malwarebytes should remove these.once they are removed make a new restore point and remove all your other restore points as they will be infected as well.
    LENOVO 64734VM
    15 inch
    External Speakers
