Latency and frame rate problem
Aires
I did a search and came up empty on this one.. Ive been playing wow and as of lately my latency spike to 251 to 301 its not bad but when Ive been playing at 150 and so its kinda a jump. My frame rate is only about 20 to 30 and some times drops to about 9. I cant seem to fix this problem. I have done numerous searchs over the net and not finding much. I did come accrossed a registry tweak but dont know I dare do that.
My system is running 2 gtx 280s sli. I have 2gs ram plus 1g per vid card. Im running a penteim processor 3.0ghz and a 250g Hard drive and an asus mother board. The only thing I dont have is a nic, Im using an onboard one but havent had problems with it.
Ive only been running vista 64 for prolly about a month now, Everyone now and then it will lock up and I will have to hard boot it. Ive run all my spyware and adware scans and not comming up with much. I recenly downloaded all my drivers after seeing the spike as well as dumping a lot of my add-ons and no success. I did find a connection upgrade that I will try when I get home from work and see if it will increase the network speeds.
I am not computer illiterate, I know somethings but nothing to do with the bios or reg never done nothing with these.
I know my computers not great but I would think that I should be getting more then 9 fps at the lowest and 250 ms. any help would be greatly apprecated.
Aires
Crispy2007
64 |3!T G33|<
Try disabling SLI in the nvidia control panel and all wow servers are in US witch is **** because people in other overseas get pings off 300+.
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
    Country Flag
    australia
    State/Region Flag
    au queensland
Aires
Alright I did this and it still had high latency if not higher. Im in the process of trying some vista tweaks but so far no luck with lowering my latency, and upping frame rate. So far this is a joke. I rolled back my drivers and nothing. I restarted the switch and modem. That didnt work. I have no clue were to go. Everything i see points me to a vista hack but I dont trust playing arround in a registry will help my latency in a video game. All the permiters in the Nvdia card seems to be functioning corectly. I did read about forcewar but didnt seem to apply to this. Maybe tommorrow I can get a hold of a tech person that wont take a week to look at my computer. Why couldnt it be just as simple as saying if you clear this it will help your latency a lot and not spike. Bah
Aires
stoneys-nutz
Gamerholic
Have you tried the teaming option in the Nvidia control panel ?, this will help some of the time. Good luck and post your results.
  • Name
    Stuart
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
    Country Flag
    uk
    State/Region Flag
    uk scotland
kiddieboy12
sloowlag
holy CRAP
you running 280gtx x 2 but your getting 20-30 fps?
what game are you playing?
i suspect internet problems.
    amd 64x2 4200+ 2.2ghz per core
    ECS NETTLE
    3 gb
    nvdia 6150se nforce 430(old rig, upgrading)
    reltrek hd audio
    hp w1907
    1440x968/1024x768
    320gb
    upgrading, Coolmax CA-450 450watts
    hp casing
    defult..
    hp
    hp
    768kbps down and 128 up...very slow..
    not great compared to other people..
Crispy2007
64 |3!T G33|<
Not all games support SLI with can or will cause problems.
    Country Flag
    australia
    State/Region Flag
    au queensland
UndeR
Hi there. I have the same problem but I discovered that nVidia did something wrong with their latest drivers so all you have to do is wait. I have a BTX 295 and also get 20 ~ 30 fps in Dalaran so don't worry about that. I do get like 80 fps while in any Ulduar boss encounter.
About the latency problems... don't worry too much. Blizzard has announced that their ISP has problems and that they are working on them. Also, you might want to try WoW Tunnels - Reduce Lag, The Easy Way.. Is not free but is VERY chep and it works. I'm in South America and got down to 200ms from a normal of 350ms or more. What node to select from the list... well, it depends on YOUR ISP. Just do a ping -t to each of those servers and go for the lowest one.
Cheers,
  • Name
    Cesar
    Custom-Built Desktop
    Intel Core 2 Quad Q9550 OC to 3.4Ghz
    EVGA 780i Triple SLi
    8GB (4 x 2GB OCZ DDR2-1066 / PC2-8500 / Platinum Series)
    MSI nVidia GTX 295 SLi
    On board
    2 x ViewSonic VA2216w
    1680 x 1050 each
    1 x Samsung 750GB / 32MB / 7.200 RPM)
    Thermaltake TR2 1000W
    Thermaltake V9
    Thermaltake Mini Typhoon
    Logitech MX Revolution
    Logitech G15
    1 mb/s
    Country Flag
    argentina
