Latest Version of Adobe Flash Player Released
32-bit & 64-bit WHQL Version: 32.0.0.255
Date Released: September 10, 2019
Details: Adobe Security Bulletin
Check What Version of Adobe Flash Player You Currently Have
Adobe Flash Player WHQL Download Page
Adobe Find Flash version
Adobe Flash Player Standalone Full Installer Download Page
- Adobe Flash Player only supports a 32-bit browser in Vista and XP, but supports both a 32-bit and 64-bit browser in Windows 7 and 8.
- Release notes
- System Requirements
- Remember to uncheck the Google Toolbar option if you do not want it installed to.
- If you have problems installing the Adobe Flash Player, then you might use the uninstaller program to remove the old Adobe Flash Player version and try installing the new version again afterwards.
- How to uninstall the Adobe Flash Player plug-in and ActiveX control
- If you use Firefox, then it uses a separate plug-in than Internet Explorer. You will need to select your OS, click Continue, and select "other browsers" to install the separate plug-in for Firefox from this link instead.
- If you like, you can check your Adobe Flash settings and clear all visited websites list history at this link or from the Flash Player icon in the Windows Control Panel.
- Operating System
- Windows 10 Pro 64-bit
- Custom
- Intel i7-8700K 5 GHz
- ASUS ROG Maximus XI Formula Z390
- 16 GB (8GBx2) G.SKILL TridentZ DDR4 3200 MHz
- Graphics Card(s)
- ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
- Integrated Digital Audio (S/PDIF)
- 2 x Samsung Odyssey G7 27"
- 2560x1440
1TB Samsung 970 EVO Plus M.2,
250GB Samsung 960 EVO M.2,
6TB WD Black WD6001FZWX
- PSU
- Seasonic Prime Titanium 850W
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Logitech MX Master 3
- Logitech wireless K800
- 1 Gb/s Download and 35 Mb/s Upload
- Other Info
Linksys EA9500 router,
Arris SB8200 cable modem,
Lumia 1520 phone
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- i7-7500U @ 2.70 GHz
- 16 GB DDR4-2133
- NVIDIA GeForce 940MX
- Conexant ISST Audio
- 17.3" UHD IPS touch
- 3480 x 2160
- 512 GB M.2 SSD
