Limited Connectivity after reformatting Vista
Hi Vista Forums
I'm sure this has been discussed to death but I just cannot seem to find a solution to my problem.
I just formatted my Girlfriends computer because she had a lot of malware and viruses. It was a system restore from a Vista to factory settings of Vista and all was done successfully, that is until I tried to connect to the wireless network in my house.
I typed in my password for it, tried connecting but nada, I just get Limited Connectivity notification within the Network and Sharing Center. :mad:
Any idea what has gone wrong? I have searched high and low on the forums and none of the suggestions they had seemed to fix my problem.
I should also mention this is not my best area of expertise so if you can keep the advice in layman's terms it would be greatly appreciated =)
Also if you need any additional data please request so, I put in everything I could think of the top of my head...cheers!
Jacee
Security
Open a command prompt, right click on it and choose to run as Administrator.
Type or copy/paste netsh winsock reset, press enter key
Reboot the computer and see if this helps
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device.
    One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
Ok I get a message saying "the requested operation requires elevation". I have triple checked the spelling, but for some reason I don't think it did anything.
I have also tried the netsh int ip reset.log but that command prompt just tells me that it does not exist.
I checked the device manager, all the hardware is working fine and proper.
Also tried restarting my router and unplugging it for 10 secs.'didn't work...
Any other ideas perhaps? Cheers for replying!
Ardneh
Are you working from a user account with admin privilege,
and did you open the cmd.exe shortcut with:
Right-click > Run as administrator
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
also here is the Ip config from her computer
Windows IP Configuration
Host Name . . . . . . . . . . . . : Amanda-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : 00-19-D2-51-4B-97
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IPv4 Address. . : 169.254.216.109(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection
Physical Address. . . . . . . . . : 00-16-D3-97-22-8B
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{3F91B814-94F7-4FB3-B0F4-DFD66A737
AA6}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{D09C1FCE-6B8A-4FAC-AB9F-AC603D295
05D}
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.216.109%11(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Hopefully that will help you extrapolate any info on what I should do. Thank you
