Local Only Problem - LAN and Wi-Fi
iya
Hi everyone
I am using an HP laptop on Windows Vista Home Premium 32bit. I recently encountered "Local Only" connection problem via LAN with a new ISP. I've been using my laptop for over 2 years and I never encountered this problem before with my previous ISP. I was also still able to connect successfully to the Internet with wireless connections.
Yesterday, I tried to remedy the problem with what was prescribed in (Microsoft Support), but it did not fix the problem. What's worse is that when I tried connecting via wi-fi today, it would not work either--the "Local Only" problem also surfaced all of a sudden. Wi-fi connection via iPhone was perfectly fine, so it is my laptop that is problematic. I am now only able to connect via dial-up/mobile internet.
I hope you can help me with this. Please let me know what details would be helpful for this query.
Thanks a lot!
iya
Here are further details on my machine. Hope you guys can help!
Windows IP Configuration
Host Name . . . . . . . . . . . . : Zarina
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter StarHub:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : StarHub
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 113.10.118.164(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 203.116.1.94
203.116.254.150
Primary WINS Server . . . . . . . : 10.11.12.13
Secondary WINS Server . . . . . . : 10.11.12.14
NetBIOS over Tcpip. . . . . . . . : Disabled
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom 802.11b/g WLAN
Physical Address. . . . . . . . . : 00-1A-73-2D-27-0B
DHCP Enabled. . . . . . . . . . . : Yes
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-1A-6B-23-5E-CD
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1B-24-C5-2B-6E
Link-local IPv6 Address . . . . . : fe80::600c:1f87:7351:2c01%8(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.44.1(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 201332278
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{3A958D30-E198-480E-B568-5A9CD3003
1CA}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.44.1%16(Preferred)
Tunnel adapter Local Area Connection* 7:
1CA}
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : isatap.{3F9ED315-D90E-429E-BF6A-C0EDAF154
534}
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : isatap.{1D5D5847-AA46-4006-B3DB-92A45ADDC
C8A}
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
Link-local IPv6 Address . . . . . : fe80::200:5efe:113.10.118.164%29(Preferre
d)
203.116.254.150
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : 6TO4 Adapter
Temporary IPv6 Address. . . . . . : 2002:710a:76a4::710a:76a4(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
203.116.254.150
MDA400
Nvidia and Intel
Power User
usa us_minnesota
Hello Iya and welcome to the Vista Forums.
If your using a Wireless adapter on your laptop, is it turned on? or is the router configured properly to recieve your router's signal?
Some people commonly forget that their internal wireless adapter is not turned on when trying to connect. What type of connection does your new ISP provide? (DSL, Cable, Etc.)
Most likely, some options may need to be or have been changed by accident on your laptop that are required to conenct to your router.
Now something's you can see is if the router and laptop's wireless channel's are the same. But more information on what wireless settings your router/laptop wireless adapter are may be needed.
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache
    (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
iya
Hi there, thanks!
At home, I do not have a wireless router so I directly plug the cable to the broadband modem (tied with cable TV). It works perfectly fine on my XP laptop but I only get "Local Only" for my Vista laptop.
When I was outside yesterday, I used the wireless connection, which also worked fine (same location) before I attempted fixing the LAN problem.
MDA400
Nvidia and Intel
Power User
usa us_minnesota
Hi there, thanks!
As of course, there isnt many "settings" for a wired/LAN connection.
I see that it is a direct connection to your Cable modem though. You can try two things, reinstall the drivers for your ethernet adapter and see if a clean start helps, or you can try to set a static IP that is used by your modem (and you should call your ISP to learn how to do so as it vary's with different connections). Please report on if it still does not work as i may have other solutions that could resolve the issue.
But try that first and see if anything is cleared up. :)
    1920 x 1200
ilikefree
newzealand
My subnet mask is 255.255.255.0
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
MDA400
Nvidia and Intel
Power User
usa us_minnesota
Yes but that is your router's subnet mask, as is mine. The modem's subnet mask is always different.
    1920 x 1200
