Lock and Switch User - Add or Remove
ByLine
How to Add or Remove Lock and Switch User from the Start Menu in Vista
Synopsis
This will show you how to add or remove Lock and Switch User from the Start Menu for all user accounts on the computer.
If you only wanted to add or remove Switch User, then see: How to Add or Remove Switch User from the Start Menu in Vista
EXAMPLE: Before (Add) and After (Remove) Switch User and Lock
OPTION ONE
Using a REG File Download
1. To Remove Lock and Switch User
Remove_Lock_Start_Menu.reg
download
B) Go to step 3.​
2. To Add Lock and Switch User
Add_Lock_Start_Menu.reg
download
4. Right click the downloaded .reg file and click on Merge.​
6. Log off and log on, or restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Manually in Registry Editor
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5C)​
NOTE: If you do not have System, then right click on Polices and click on New and Key, then type System and press Enter.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
5. To Remove Lock and Switch User
A) In the right pane of the System key, right click on a empty area and click on New and click DWORD (32 bit) Value.​
B) Type DisableLockWorkstation and press Enter. (See screenshot below)​
C) Right click on DisableLockWorkstation and click on Modify. (See screenshot below)​
6. To Add Switch User
A) Right click on DisableLockWorkstation and click Delete. (See screenshot below step 5C)​
B) Click on Yes to confirm the delete.​
7. Close regedit.​
8. Log off and log on, or restart the computer to apply the changes.​
  • Remove_Lock_Start_Menu.reg
  • Add_Lock_Start_Menu.reg
Zhizara
The screen originally showed a sort of button with my user picture with my name below it and with the word "locked" beneath. Below that "button" was another button saying "Guest" and "switch user" below the word "guest".
Now the Guest button is gone, but my "button" is still there and still says "locked". All I have to do is hit enter or click on the button and go about my business, it's just annoying that I can't get it to do what I want. I guess I'll just have to live with it.
The screen is a Vista background, and the only other thing on the page beside the two (now one) button is a accessibility wheelchair logo in the bottom left corner. When I press that it just takes me to the accessibility portion of Control Panel.
I do not have lock on my start menu, nor switch user, I'm not positive, but I really don't think they were ever there.
I'm the only person who uses my computer, so I don't have a password nor do I ever plan to. I just don't put sensitive information on the computer.
I do appreciate your trying to help and thanks for taking the time.
Sally
    Compaq Presario F572US
    AMD Athlon 64X2 Dual Core Processor TK-53 1.70 GHz
    1024MB DDR2 memory 80GB hard drive
    Generic PnP Monitor on NVIDIA GeForce Go 6100
    1280 by 800 pixels
    Synaptics touch pad and external generic ball-less mouse
    built in laptop keyboard
Brink
Staff member
mvp
Ok Sally. I understand what you mean now. The other posts were removed to keep this on track.
You are talking about at the log on screen for when you click on Lock or Switch User in the Start Menu. This is completely different than what this tutorial is for. This tutorial only adds or removed the Lock or Switch User from only the Start Menu as in the example screenshot at the top of the tutorial.
Anytime you click on Lock from the Start Menu, Lock will always appear under you (user name) icon on the log on screen until you logon again.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Zhizara
Lock is not on my start menu. To the right of the power button is an arrow which, when clicked offers me Log Off, Restart, Sleep, Hibernate and Shut Down.
I never had this screen before I recently did a system restore back to the factory level. This computer was still in the box when I got it and I made the backup right away as directed in the instructions.
I just want to get it to go away. It seems ridiculous that it only does itunder those circumstances. I'm not even sure whether it's hibernating or sleeping, but that's the only time the screen comes up. Unfortunately, I just close the laptop when I go to bed so I get it every day, sometimes several times a day since I often close it when I got out or just let it turn itself off naturally (I think 20 minutes).
If I can unlock my user account do you think the screen will go away?
    1280 by 800 pixels
Brink
Staff member
mvp
    Lumia 1520 phone
Zhizara
Bingo. In the Power Options, I found Choose what closing the lid does. It had require password on resume checked. I checked the other box and saved it.
Thanks so much!!
Sally
    1280 by 800 pixels
Brink
Staff member
mvp
You're welcome Sally. That's is great news. I'm happy to hear that you got it sorted out. :geek:
    Lumia 1520 phone
Brink
Staff member
mvp
    Lumia 1520 phone
popcornUoT
I already read that post before. But after a second look at it, I have come up with an idea. I can disable both the Lock and Switch User options from the Start Menu while keep the Switch User in the Windows Security screen.
Thanks for your reply and, also, your welcome.
PK
Brink
Staff member
mvp
PK, I'm happy to hear that you got it sorted out. Thank you for sharing your results. :)
    Lumia 1520 phone
