Solved Locked Out
Neverhavemoney
Hey everyone,
Its been a while! Talk about growing up quick haha! Anyways....
My gram asked me to fix her computer.... She let me little cousin try and fix it and he reset the password for whatever god forsaken reason. Now she is locked out.... I could install a second version of an os on her computer but she has almost no space left....
I have tried everything to get some sort of hint. The only thing left that i can do is reinstall everything and she said that is not an option because she has a ton of personal info on there.
Can anyone out there help a fellow NeRd out?!?!:D:D:D
Thanks,
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
Hey Ben,
Haven't seen you for a while - doing fun things , I hope.
D/l this , burn the .iso image to cd ( use isoburner.exe - attached ), boot it and blank the password. Should get your Gran back in.
Offline NT Password & Registry Editor
View attachment isoburn.exe.zip
Edit: LOL - Shawn posted the same thing while I was searching for a copy of isoburner.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
LOL. ;)
Thanks a ton guys.... I will do that tomorrow if i can... Hockey 4 nights a week and working the weekends, there is almost no time haha!!!
Thanks a ton guys,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
You're welcome Ben. Please let us know how it went. :)
Hey Brink and SIW,
Didnt work... Tried it threee times on my Memere's computer and twice on mine and none of them worked. I read the tutorial and also the directions on their site. Nothing. I dont know what/if i did anything wrong.
Is there anything else i can do or am i SOOL?!?!?:cry:
Thanks,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Hi Ben,
Well, if using the option in the link above did not help, then you can place your hard drive in a friend's computer temporarily to manually backup anything that you do not want to lose off of it before doing a clean reinstall. :(
Hi Ben ,
If it didn't work on both machines - you may not be doing it right.
You are in luck, there is:
Paragon Rescue Kit Pro 8.5
being given away - they have new version so are not selling it any more.
It was on GAOTD recently - so is bound to be given away elsewhere - google it.
It will probably come in a rmb.exe - when you run that, click the link it pops up to get your free license key. It burns itself to cd.
Boot the cd - select Pasword cleaner - and it couldn't be easier.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
I was just about to Brink then SIW comes in to give another hope for me. Thanks a ton SIW and i will try this one tonight and will report back.
Thanks a ton guys,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Paragon Rescue Kit Pro 8.5 not available anymore. 9.0 has trial and $$.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Hey SIW! Your the f@!#$!@#$!@ man!!!!! Thanks a ton! I found a give away of Paragon Rescue Kit Pro 8.5 and it was about 3 clicks with the mouse and i was golden!
Thanks so much!!!!
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Hey Never - you found that today? And it registered?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Ben, I'm happy to hear that you got it sorted. :)
Great Ben , I bet your gram is happy.
Paragon are good like that - they let you register /re register their stuff - even the giveaways, pretty much forever. They don't want people to be stuck if they need to reinstall, etc.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Paragon 9.0 Express is still FREE...
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Yep,
Thanks SIW and Brink.
Brink, maybe you should add this to the tutorial. It was very useful for me.
Thanks again everyone,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Yep,
Ben
I would Ben, but it's not a free program, so it's a no go. :(
Even though there is a free trial?
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
