login problem
inspector
i am having trouble with login to www.pbdisasterservices.com as a user because of Vista op sys. talked to their tech serv rep and it is some sort of vista problem. talked to hp (my computer mfg) and they could not help. microsoft said to go to self help site--could not find anything close to my problem. ANY suggestions from anyone? after login, screen will blink and return to a blank login. each time i fill in login info and hit login, the screen will reset to a blank login.
z3r010
Staff member
Have you tried using a different browser?
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
inspector
i need to go to the website first, then to their login portal where i get the login window. the login window is just 2 lines or blocks. name and passsword. i enter these and all the screen will do is blink and reset to a blank login wondow again.
z3r010
Staff member
Have you tried using firefox or chrome to go to the website?
    Windows 10
    me
    Creative
    6 @ 2560x1440
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Brink
Staff member
mvp
Hi Inspector, and welcome to Vista Forums.
In addition to the above:
Do you have cookies enabled for that website? Sometimes a website will require them to be enabled for it to allow you to login.
http://www.vistax64.com/tutorials/60641-cookies.html
You might also check Pop-up Blocker to see if it is blocking the website from opening another window or tab. This can happen if Pop-up Blocker is set to High instead of the default Medium sometimes.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
