Lost "bitrate" as detail folder option
ManorMusic
Have Vista Home Premium on 2 computers. Working with music on desktop and want to see "bitrate" on the tracks in the music folder but it isn't listed as a detail option. It is on my laptop. Any suggestions on how to get it on the desktop?
Hi ManorMusic and welcome to Vista Forums :party:
This problem occurs when the folder template is set incorrectly. Here is the Sample Music folder set as Documents. You can see that the items available for the columns in Detail view do not include Bit rate.
attachment.php
To correct this, right click on a blank section and select Customize This Folder...
attachment.php
Select the Customize tab, if not already selected. In the first drop down box under Use this folder type as a template: select Music Details and click OK.
attachment.php
Notice that the items available for the columns in Detail view now include Bit rate. Also notice that the toolbar now includes the Play all button, whereas previously it didn't.
attachment.php
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Thanks for the assist. The "play all" is available, but bitrate is still not. Think somehow the details were corrupted ... is there a way to restore them?
