Loud whirring noise
eknirb
Sudden CPU Loud whirring noise
Sitting there as usual, looking at email, nothing out of the ordinary,
all of a sudden, from nowhere, LOUD whirring noise coming from CPU.
Never heard this before.:confused:
Rebooted---it's gone. Maybe this SSs help, I've never really been one to understand performance data. I've left the PC on for a week- usually shut it down nightly. Could it be the temp?
By thinkbrinke at 2010-05-08
    HP m8200n Windows Media Center
    AMD Athlon 64x2 Dual Core Processor 6000+ 3.00GHz
    3.00 GB
    HP widescreen w1907
Brink
Staff member
mvp
Helllo Eknirb,
From looking at your top image from Task Manager, it looks like you had a spike in CPU usage there for a bit. That spike may have cause your built-in motherboard fan controllers to rev up the CPU fan to keep it cooler with the quick increase (spike) usage.
Monitor your CPU temps to make sure that they are not high or spiking on you as well to be safe. 45C as your showing in the last screenshot is ok. If they are high all the time, the CPU fan or heatsink may be loose, or you may need to clean and replace the thermal past on the CPU heatsink.
If the usage is spiking on you randomly, then you can look under the CPU bar in Resource Monitor to help see what is using so much of the CPU.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
eknirb
I seem to have noticed AVG turned on at that point- could that be it?
    3.00 GB
    HP widescreen w1907
Brink
Staff member
mvp
I suppose if it was doing a scan at the time, it could be if the increased CPU activity caused the CPU to heat up enough to have the CPU fan increase it's speed.
You could test this by manually running a scan to see if it does the same.
    Lumia 1520 phone
eknirb
I uninstalled AVG and rebooted- it presented me with no desktop, just asolid royal blue background.
rebooted again,
desktop after long delay appeared, plus a browser window automatically asking me why did i uninstall aVG.
    3.00 GB
    HP widescreen w1907
Ozirus
Did it sound like a Laser Beam cutting through Glass?
If so, your processor is blown.
    Acer Aspire T180 - Desktop
    AMD Athlon 64 2.4 GHz (single core)
    Chipset - nVidia MCP61/nForce 430 GeForce 6150SE
    R.A.M. - 3072 MB DDR2 PC2-5300 (333MHz)/667 = 2(1024 MB), 2(512 MB)
    XFX GeForce GT 240 {1GB DDR3, 550 MHz GPU, SM 4.1, dx 10.1}
    Onboard Realtek HD Audio ALC888
    Acer AL1706 LCD 17"
    1280 x 1024
    Hitachi 160 GB SATA, Partitioned into C: and D:
    Rogers Hi-Speed Express (10 MB/s download, 512 kb/s upload.
    AVG Internet Security
Brink
Staff member
mvp
In addition, how clean or dusty is your CPU fan? If the fan itself is going out, it can make a loud whining or squealing sound.
    Lumia 1520 phone
MWRed
I'd rather be fishin
Vista Pro
Agreed, it sounds like a fan controller increased the fan speed to cool something down. I can do it manually on my case, and it is pretty loud and annoying as hell.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
eknirb
hasn't done it since I rebooted, so who knows? CPU Core temp @ 46-51c
    3.00 GB
    HP widescreen w1907
Brink
Staff member
mvp
That sounds about normal for the temps. I'm assuming that the CPU fan is spinning since the temps are not any higher than that.
    Lumia 1520 phone
