LOUD whirring noise
eknirb
PC started up fine.
Loaded fine.
All programs loaded exactly as normal.
About 30 seconds in....RRRRRRRRRRRRRRRRRRRRRRRRR
and I mean loud.
I shut it down, and rebooted. Nothing again.
Whadya say?
    HP m8200n Windows Media Center
    AMD Athlon 64x2 Dual Core Processor 6000+ 3.00GHz
    3.00 GB
    HP widescreen w1907
richc46
Sounds like it might be the fan
Download speed fan and check for overheating
eknirb
overheating @ startup? After :30 of up-time?
    3.00 GB
    HP widescreen w1907
richc46
Dont know where you are or the temperature of the area of the computer. In another month here (NY Area) on the top most floor the temps will hit high 80s in the day.
Also donk know the last time that you used the computer, before starting up.
Also can be a DEFECTIVE fan sensor.
eknirb
lo 60s in the Bay Area. Will keep an eye on it. It's almost 4 years old and OOW, so it's not going in for repair.
    3.00 GB
    HP widescreen w1907
richc46
