Mass Storage Controller
Cloud
Hello, please see the attachment of my PC's problem and please help!
Thank you guys!!
    TOSHIBA
    Itel(R) Core(TM)2 CPU T5500 @1.66GHz 1.67GHz
    2GB
    nviDIA
You need a new driver. Go back to device manger and update driver or even better go to website and get the best driver.
Is this an external hard drive and did it come with software?
I see it is listed under other as Massive Storage with yellow flag on it.
    HP Pavilon Elite
    ASUS eK Berkeley
    That's where I keep my beer
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
Hi, thank your for the prompt reply.
I tried to right click the 'Mass Storage Controller' and choose 'Update driver software', but after loading for a while, the pop-up screen said 'unable to find the driver software' and ask me to 'find the manufacturer of the device'.
I have no idea how to find it by myself. what website do you suggest to get the best driver?
thank you.
    TOSHIBA
    2GB
    nviDIA
To The Howling Wolves:
I am not sure if it is an external drive, but it is very likely. I tried to uninstall some programme on my laptop last week, and I think I probably deleted some programme that I shouldn't. I can't remeber what it is. Is there any way I can find out what I have mistakenly uninstalled?
Thank you.
    TOSHIBA
    2GB
    nviDIA
The reason I ask for soluation for this problem is that, I think, it affects the performance of my laptop. I have been having trouble recently to switch on my computer, the system seems not to respond. I have to force to switch off the computer and turn it back on again by choosing the SAFE MODEL. I then run a system restoration under the SAFE MODE, only by doing that, I can get back to the normal window and use it.
Do you guys think it is anything to do with this Mass Storage Controller? can I just disable it and ignore it, or I need it to be fixed to run my PC properly. ?
Thanks guys.
    TOSHIBA
    2GB
    nviDIA
Another idea Rich is he might do a System Restore to when everything was working and the Word doc item was present.
If he gets the Word Doc back, then he needs to back up his files so this doesn't happen again.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
That would work, unless the driver is corrupt or outdated.
Hi Richc46,
I followed the instruction you sent me, but it turned out to be the same message I got after run searching from my compture. It says ' can not find the driver software.
    TOSHIBA
    2GB
    nviDIA
That is probabley a driver for your usb. If computer is working without problem and you do not need the usb port, your ok.
Go to My Computer and see how many drives it is showing.
Did you add an extra drive to your computer?
I have a desktop and laptop and neither one shows Other/Mass Storage.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
Mine does and they are all Microsoft.
Here's where you might try to restore it.
I picked D by mistake...Yours will be C
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
