MCE does not play recorded TV anymore!
Volkert
after installing a new video card my MCE does not play recorded TV, Live TV or DVDs anymore. It will play for a few seconds, and then crash.
If I play a file of recorded TV with Windows Media Player, it works fine.
The card I installed is a ATI Radeon HD 5450, 1Gb.
I can still play recorded TV from my Extender, so functionality seems OK.
Any advice is highly appreciated!
Volkert
    Intel(R) Pentium(R) 4 CPU 3.00GHz
    ATI Radeon HD 5450
Yard Dog
Hello, i would check Device Manager in your Control Panel and make sure i had correct driver for it installed
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Volkert
Thanks Yarddog. I have re-installed the correct driver just to be sure but it still did not work.
Volkert
    ATI Radeon HD 5450
Yard Dog
Does it seem as if it is over heating when this happens ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Volkert
no. It just seems like a buffer is filling up and once it is full, MC stops working and fails.
What I don't understand is why Windows Media Player can play the file but MC cannot.
Volkert
    ATI Radeon HD 5450
Yard Dog
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Lottiemansion
What card did you have before the upgrade?
Have you removed all the old drivers? These might be in conflict with each other, not sure though.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
