Mechwarrior 4 Vengeance Won't Run
Madandfrustrate
Interpretor
184
Location
British Columbia, CA
I was bored today, so I found my Mechwarrior 4 Vengeance disk and decided to play a bit. It installed fine and I'd ran it before, but then when I tried to run it, the disk would spin and I'd get the loading image. The disk suddenly stops spinning, then the program closes and I get the same old "This program has stopped working..." error. I've tried compatibility modes and running as administrator, but I still have no idea what's wrong.
Any help here? Thanks.
    Gateway DX4860
    Intel Core i5-2320 @ 3.00GHz
    6GB DDR3 SDRAM
    Zotac GeForce GT 240 1GB GDDR5
    Intel H67 Express
    Samsung SyncMaster 2253LW
    1680x1050 @ 60Hz
    SATA II 1.5TB Hard Drive
    450 Watts
    NexxTech Wired Optical Mouse
    HP 5189
    Telus High Speed 15mb/s
Chase
americano
1,571
Location
Merced & Monterey, CA
Try completely uninstalling the program.
Then do the following:
Press the Windows key + R.
In the Run Command type: msconfig
Select the "Services" tab
Check the "Hide All Microsoft Services" box
Click "Apply"
Click "OK"
Restart your computer and reinstall the program.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
Madandfrustrate
Interpretor
184
Location
Click "Apply"
Click "OK"
I don't know what you're trying to get at, but that did absolutely nothing...
Uh, could you explain to me how not showing the Microsoft programs would do anything, I couldn't even press apply since nothing changed at all.
Thanks for your help anyways.
    Gateway DX4860
    6GB DDR3 SDRAM
    Intel H67 Express
    1680x1050 @ 60Hz
    450 Watts
    HP 5189
Madandfrustrate
Interpretor
184
Location
Click "Apply"
Click "OK"
Did some digging around and solved my problem. all I had to do was disable Spyware Doctor (Damn thing causes so many problems I'm considering getting rid of it.). Thanks for trying!
    Gateway DX4860
    6GB DDR3 SDRAM
    Intel H67 Express
    1680x1050 @ 60Hz
    450 Watts
    HP 5189
Chase
americano
1,571
Location
Click "Apply"
Click "OK"
Yeah, sorry about that, I left out the step to disable all other services. My thought was that there was some third party service interfering with the installation. It must have been the Spyware Doctor.
Hope you resolved the problem.
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
