Media Player Classic and AC3
Hey,
Im using the k-lite mega codec pack which has media player classic. Everything works fine until i play ac3 files - the volume is really low. Does anyone have the same issues and know how to fix?
Cheers,
Joronamo.
mattinahat
m@thue
Power User
Do you mean AC3 files from a dvd?
If so then all DVD audio tracks are for one reason or another of lower volume than say an mp3. Thats just the way they do it and i dont know why.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
Hey
Don't worry I just opened up the ac3 configuration tool and adjusted the maxium gain to 20 decibals and its loud enough now - still weird though.
Cheers,
Joronamo.
mattinahat
m@thue
Power User
Funny you say that because when i used to have problems with WMP (and there were plenty of them) and DVD's i would use WMPClassic and all ac3 files worked (rips from DVD's) played fine...
What ac3 decoder do you use. I use AC3Filter. It has a really good GUI and everthing.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
Hey dont worry i fixed the problem,
For some reason my mpc didnt have all the audio filters selected including ac3. But i selected them all and now the volume works fine. Gotta make sure everything is checked.
Cheers,
Joronamo.
mattinahat
m@thue
Power User
Glad you figured it out :)
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
