Media PLayer no longer plays wmv files
qdmcgraw
I've been using windows movie maker for months now. no problem with it.
Recently, the WMplayer in the account where I've been using wmovie maker no longer plays wmv files- old or new. KM player will play all wmv files in this user account and the other user accounts. this user's winmedia player seems to play all other type of video files that it has been designed to play except wmv- old or new.
i've switched to other accounts and wmplayer will play wmv files in those accounts.
facts:
Sony laptop. 3 years old. Vista. Home computer. I am the administrator and have full access to all user accounts. Windows Media PLayer states that my computer is running the latest updates. The problem seems that the win media player in this user account has been broken. I looked at user's local data folders and don't see anything unusual or missing. Any suggestions (besides closing the account and open a new one)?
Thanks
tom982
٩(͡๏̯͡๏)۶
  • Name
    Tom Smith
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
    Occupation
    Student
    Country Flag
    uk
    State/Region Flag
    uk england
qdmcgraw
Thanks for the reply... but WMplayer was always the default player for .wmv files. I reset it in Default Programs just to be sure, but no go. So far, I've opened up a new user account and WMplayer handles .wmv files in the new user and the administrator accounts just fine. I may have to migrate all the stuff from the current user account with the broken WMplayer to the new user account and shut down the old account. This problem perplexes me because I thought that the basic core of codecs, permissions and updates of WMPlayer was universally shared to all user accounts. Why just that one account can not play .wmv but everything else it's suppose to play is a puzzle.
Anyways, thanks for the suggestion.
Any other ideas?
qd
eldinv
So when you play or double click a video file (.wmv) it opens and plays in KM player?
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device
    Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
    Country Flag
    usa
qdmcgraw
No matter how I try to open a .wmv file to play using WMPlayer, I get this error message:
"Windows Media Player cannot access the file. The file might be in use, you might not have access to the computer where the file is stored, or your proxy settings might not be correct."
KM Player is not the default player, I must choose it to play .wmv files. In order to play a .wmv file with KM Player I must either open the file with KM Player (KM PLayer is running) or right click on .wmv file and select Open With KM Player.
This problem exists only in one user account. In the other user accounts WM PLayer works as expected.
qd
eldinv
qd
There's no reset option for Windows Media Player without messing with the registry. It sounds like a secruity issue with the file itself but I can't be for sure. Where is the file located? Is it being used by another program, torrent. :mad:
If it just started happening, doing a system restore. If too much time has lapse since the problem started, my suggestion would be although its a pain, create a new user account and restore your files there.
Microsoft Fix it Solution Center
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Country Flag
    usa
qdmcgraw
I've tried everything reasonable to fix the problem, inculding system restores, etc. I haven't fooled with the central registry. I won't go there because WMPLayer works in the other accounts except this one and I fear messing up the registry by poking around in it. I don't use bit torrent or go to any suspect websites or download anything that I don't know exactly what it is. I've looked for any problems in that user account's AppDate folders (Local and Roaming files) and everything looks all right. The problem occurred after I started using WMovie Maker extensively. Everything else works in this account except for this peculiar problem.
Last week, I've already started the process of migrating data from this user's account to a new user account, because I suspect that the solution is beyond solving without having to go into the registry.
Thanks for looking at this one, mate.
cheers-
qd
tom982
٩(͡๏̯͡๏)۶
Why do you have Kmplayer installed? Do you need it?
Another thing you can try is a SFC scan:
SFC Scan:
1. Open the start menu
2. In the search box, type cmd
3. Right click on command prompt and select Run as administrator
4. In command prompt, type:
sfc /scannow
5. Let it run and let me know if it finds any Integrity Violations
Tom
  • Name
    Tom Smith
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Occupation
    Student
    Country Flag
    uk
    State/Region Flag
    uk england
qdmcgraw
Tom,
Good tip. I forgot about trying sfc /scannow.
I tried it and WRP did not find any integrity violations.
I've been using Kmplayer for almost 2 years now on two of my Vista machines and haven't had any problems with it. I use it to play various video files. Mostly I use WMPLayer and "WinDVD for Vaio" for my other mulitimedia needs. As an aside, Media Center plays .wmv files.
This current problem with WMplayer has appeared within the past 6 weeks and I think it is linked with my heavy usage of video editing with Windows Movie Maker. I noticed the problem one day when I published a video to the computer, as usual, and the option of 'Play movie when finished Publishing' opened up the WMPLayer- but WMPlayer could not play the .wmv file. After that WMPLayer couldn't play any .wmv files including the sample videos that come with Vista. So, my suspicions point to Window Movie Maker as the trouble maker.
qd
tom982
٩(͡๏̯͡๏)۶
Ok, if you were able to play these "various video files" in WMP, would you?
If the answer is yes, can you download and install the K-lite codec pack please:
MajorGeeks.com - Download Freeware and Shareware Computer Utilities.
1. Download the above installer, and run it
2. Select Advanced Install
3. Click Next
4. Select Profile 8: Lots of stuff (without player)
5. Click Next
6. Select Windows Media Player and click Next
7. Tick every box and click Next
8. Tick every box and click Next again
9. Select 2.0 Stereo, unless you have better, and click Next
10. Click Install
Tom
  • Name
    Tom Smith
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Occupation
    Student
    Country Flag
    uk
    State/Region Flag
    uk england
qdmcgraw
Tom,
1. I downloaded and ran the K-Lite per your instructions.
2. During install K-Lite informed me that DirectShowFliter was broken in Reg Key, H-Key Classes-Root-CLSID-Instance\AVI Writer Filter. (I'm leaving out some letters and stuff)
3. K-Lite seemed to have installed with no problems.
4. I restarted the computer and tried to play a .wmv file with WMPLayer. No go. Not even the Vista Sample Videos.
5. I tried to play other vid files with WMPLayer: IFO, VBO, AVI. They all worked.
Fact: This "broken" user account is either the owner/ceator or has shared permission of the .wmv files. So, something is broken either in the registry or AppData. That's my guess.
I've known about the K-Lite pack for sometime and never tried it because of fear of it screwing up my OS. But I took a chance on your recommendation and the GeekMajor website.
Thanks for the info.
I am not willing to try any type of "registery cleaner." I used CC on my XP's and it helped run the XP's a bit faster, but I'm not gonna take the chance on this Vista machine because it's running "clean" except for this odd problem with this user account.
I don't think that even the Microsoft engineers could get this one.
Again, thanks for your efforts. This account will be eventually shut down, even though everything else works in it. At this point, I'm more curious as to what's causing the problem than expecting that we'll find a fix. Of course, it would be nice if Micrsoft had a "repair" option for its built-in programs.
cheers-
qd
tom982
٩(͡๏̯͡๏)۶
Yes, well done about the registry cleaner point, because most times a registry cleaner/optimizer will do more damage than it fixes.
Do you have a Vista installation disc? (assuming that you have vista, if not, do you have the installation disc of your current OS?)
Tom
  • Name
    Tom Smith
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Occupation
    Student
    Country Flag
    uk
    State/Region Flag
    uk england
