You should upgrade or use an
alternative browser .
Solved Memory Error on Vista
I have an HP Media Center PC and it seems that it has a memory problem because when I turn it on there are two beeps, a long one followed by a short one. The fans and hard drive are running.
Download and test the memory with memtest. If you cannot do that, get a known good ram stick and see if it works any better.
٩(͡๏̯͡๏)۶
Build #1
Intel Core i7 3770K @4.4GHz
ASUS P8Z77-V PRO
Integrated on motherboard
23" LG LCD/LED IPS
1920*1080
Samsung EVO 128GB SSD
Seagate Barracuda 2TB 7200rpm
NZXT Phantom 410
Thanks Tom
Im not home with my favorites. Your link came in handy. rep+
٩(͡๏̯͡๏)۶
Its no problem at all Rich - glad I could help
Thank you for the rep
Tom
Build #1
ASUS P8Z77-V PRO
23" LG LCD/LED IPS
1920*1080
NZXT Phantom 410
Thanks, but I fixed it already.
I opened the case and cleaned the RAM sticks. It's working perfectly now.
Thanks
٩(͡๏̯͡๏)۶
Thank you for taking the time to share your solution with us
I'm sure others will benefit from your troubles
Feel free to pop back if you have any further questions
I will mark this thread as solved
Tom
Build #1
ASUS P8Z77-V PRO
23" LG LCD/LED IPS
1920*1080
NZXT Phantom 410
