Mic Boost
3
Can someone post the regedit for enabling mic boost for vista ultimate x64? I had it before but then reformatted and lost the directions. Please help and thank you very much.
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Cakewalker and welcome to the forums :party:
This is actually easier to do through audio properties. I don't know what audio you have on your system, but the following step by step instructions are for mine and should be easy to adapt for yours. If you want specific instructions, please supply more details of your system.
Dwarf
1) Right-click the speaker icon in the system tray.
2) Select 'Recording Devices'.
3) Highlight 'Microphone'.
4) Click 'Properties'.
5) Select the 'Custom' tab.
6) 'Mic Boost' is on this page. Enable or disable it as required.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Cakewalker
3
Thanks for the reply but there is a problem with it. My custom tab does not have the mic boost option. I was actually able to go into the registry and searched for MicBoost and found the reg I needed. It was default set to 0 so I flipped it over to 1 and now everyone can hear me clearly. The location of the MicBoost regedit is:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E963-E325-11CE-BFC1-08002BE10318}\0000\Settings
Scroll down on the right hand side and look for MicBoost. Double-click it and put a 1 where there was a 0. Now you have MicBoost and everyone is happy.
coolchris
NoNonsense
Vista Pro
278
Location
Barnsley, UK
Nice find. Ill have to remember that one!
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
johngalt
Antidisestablishmentarian
3,912
Location
3rd Rock
I can only go as far as
Code:
- I have a 0000 entry (and 0001 - 0004) but none of them have a Settings sub key. In fact, none of them have *any* sub keys.
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
Cakewalker
3
did you try just doing a search in the regedit? Open regedit and hit ctrl-F and type in "MicBoost" one word. That brought it up for me so hopefully it will work for you to. Good luck.
johngalt
3,912
Location
3rd Rock
    Yes
    Operating System
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
    Dell Inspiron 3521
    Dell
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Dell
