You should upgrade or use an
alternative browser .
Microphone on Vista Sounds Muffled
I was just on Ventrilo Talking to people and skype also and they said that my microphone sounded muffled . SO i called the echo test service for skype and heard that it was . It sort of sounds like im in a tunnel and or have something blocking my mouth . Can anyone help me with this . It has only started this when i switched to windows vista 32 Bit I was on Xp before hand Please help me quick i need this resolved
1x1x2 Gig DDr2
Ati Amd Radeon x1300
Seagate 2 TB HDD
Razer Lycosa Gaming keyboard
Razer naga 17 Button MMo Gaming Mouse
٩(͡๏̯͡๏)۶
Hello Rob141 and welcome to the forums
Try this:
Uninstall Driver
Open the start menu
In the search box, type Device Manager and open it
Expand the Sound, video and games controllers category by clicking on the little + sign
Right click on everything in there and select Uninstall
Reboot your computer after that finishes
Tom
Build #1
Intel Core i7 3770K @4.4GHz
ASUS P8Z77-V PRO
Integrated on motherboard
23" LG LCD/LED IPS
1920*1080
Samsung EVO 128GB SSD
Seagate Barracuda 2TB 7200rpm
NZXT Phantom 410
Hi Tom . I was on the phone with Dell Technical support and I have gotten them to do all that remotely . I uninstalled all the drivers and anything that has to do with sound . They are still not working .. Im goin to try and install a couple of audio codecs and some other software that i have on my other hard drive to see if that works
Thanks Robert
1x1x2 Gig DDr2
Seagate 2 TB HDD
٩(͡๏̯͡๏)۶
Hi Robert,
Okay, that's great. Let me know how it goes! I'll have a search around whilst you do that.
Tom
Build #1
ASUS P8Z77-V PRO
23" LG LCD/LED IPS
1920*1080
NZXT Phantom 410
Nope Still hasn't worked . Now the sound is completely shot .. All I can hear is static coming out not even muffled
1x1x2 Gig DDr2
Seagate 2 TB HDD
٩(͡๏̯͡๏)۶
That's not very good
What codecs did you install?
Tom
Build #1
ASUS P8Z77-V PRO
23" LG LCD/LED IPS
1920*1080
NZXT Phantom 410
Ive installed all the codecs and found out that it wasnt the codecs at all It is the microphone port on the back of the computer Just not gonna worry about it now going to build my own computer Thanks for the help tho
1x1x2 Gig DDr2
Seagate 2 TB HDD
٩(͡๏̯͡๏)۶
Hi Rob
Okay, no worries. Hopefully that one won't have any problems!
Tom
Build #1
ASUS P8Z77-V PRO
23" LG LCD/LED IPS
1920*1080
NZXT Phantom 410
