Solved Microsoft ISATAP Adapter#3
laserredv2
My notebook won't accept any updates.
Norton tells me Microsoft ISATAP Adapter #3 device is not working properly Windows cannot load the required device drivers(code 31)
Play and plug ID; ROOT\*ISATAP\0002
I tried to update this but it said it was updated and working, Norton device manager says it isn't.
Any one know of a fix for this?
    HP Pavilion dv2500 Notebook PC
    AMD Turion 64X2 TL-58 1.90 GHz
    2 GB
    Nvidia
Shadowjk
Network Enthusiast
In device manger Right click the Driver and click uninstall after that Restart your Computer and it should reinstall the drivers
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
laserredv2
thanks I'll give that a try
    2 GB
    Nvidia
laserredv2
Thanks Josh That worked Happy Holidays
    2 GB
    Nvidia
Shadowjk
Network Enthusiast
No Problem, some drivers in Vista don't load properly reinstalling them should fix the issue,
Though be warned if you Reinstall a Network driver you may need to re enter the Passwords to use your router if you own one
Happy Christmas,
Josh
    AMD HD Radeon 6870
    Novatech Night
niemiro
Banned
Hello!
Is this a Windows Update, or a Norton Update. Is the issue still present? Would you like help with it?
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Dannyi
Hello,
New to the forum,and would be delighted with any help I can get.
Have Network Adapter issues with DELL Inspiron 1525, basically would not let me connect to the internet.
Followed the trail instructions - uninstal (both 3 and 6) and reboot - it reinstalled but did not change situation.
Then I disabled (both 3 and 6) and tried to re-enable using ACTION via Device Manager and clicking Add Legacy Hardware and used the wizard to install Microsoft ISATAP. It said the installation was successful. The ISATAP 3 and 6 icons did not appear under Network Adapters in Device Manager. When I rebooted, the wireless adapter also stopped working. The machine is still not connecting to the internet.
Any hope for me? Please help!
Great regards,
Dannyi
    Dell inspiron 1525
