Microsoft Visual C ++ Runtime library
2
Hi, I get this message when I turn on my computer:
"Microsoft Visual C ++ Runtime Library
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information"
I dont get the chance to log on to windows because of this message. What can I do to solve it?
I would really appreciate your help!
pauliewalnuts
Chief Flapajaw
Power User
278
Location
Columbia, MD
I'm looking at past solutions and they're kind of questionable. They involve 1) downloading and installing older versions of software that are known to cause C++ runtime errors, 2) sales pitches that only want you to buy third-party software, and 3) solutions proposed on this board in which, sadly, the OP doesn't reply back to on whether or not they worked!
Your problem affects the computer's very basic logon procedure, so it is a big problem that solution 1) won't fix, solution 2) might fix but may prove more expensive than it should be, and it's something that solution 3), well... there's none that way as far as I can research via Google.
I would start through the tools available to you in Vista. Safe Mode boot using your F8 key at your computer's initial boot screen, open your Start Menu, open "Accessories" menu. Right-click on "Command Prompt" and left-click on "Run as Administrator."
Type in sfc /scannow. Wait until it's done. Reboot.
See if the computer boots up successfully. If not, shut down. Reboot into Safe Mode. Repeat sfc /scannow (the tool sometimes only fixes one file at a time). See if it works in regular boot. If not, shut down.
While you're in one of those Safe Modes and before you run sfc, open your "Control Panel." Open "Programs and Features." You see a list of all installed programs by name, publisher, installation date and size. Click once on the little grey arrow to the right of "Publisher." You've sorted all installed programs by publisher. Scroll down to "Microsoft Corporation"-published programs.
You are looking for anything that says "Microsoft .NET Framework." There should only be one of these. Write the version number down and the service pack; for instance, my installed version is 3.5 SP1 for a 64-bit Vista installation.)
Anyway, if sfc doesn't work, you can try and force a .NET framework fix. The .NET framework is a big-ass library that contains information Vista uses to read and run popular and common third-party languages (like C++, which is a powerful language that's very commonly found. I loves me some C++). Anyway, because of its size this "library" can accidentally manifest an error, and since it's integral to the operation of many programs it's pretty darned important.
On the official Microsoft site .NET framework download page there is a list on the right of prior versions of the framework as well as the latest package, but you don't want to download the latest package if it's not the version you saw in your list of installed programs. You want the version and service pack you have right now. Find it and download it.
Then carefully read "how to repair an existing installation of the .NET Framework" and do what it says.
If that fix doesn't work, holler back.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246
    I like chocolate milk!
2
Thank you for trying to help pauliewalnuts!
Unfortunately I didn't get any further with your tips:( The link in the bottom of your message doesn't apply to my .NET framwork (3.5).
Do you know about any other possible solutions?
I'm very grateful for your help!
pauliewalnuts
Chief Flapajaw
Power User
278
Location
Columbia, MD
.NET Framework 3.5 SP1
^that's .NET framework SP1. All 3.5 versions are "SP1."
Pull a Michael Jordan: just do eeet.
    stock 1280 X 800
    stock
    stock
    stock
11
Location
South-central U.S.
my problem with runtime c++ is when lavasoft/ad-aware failed to work and i uninstalled it so i could reinstall it.
    gigabyte GA-F2A88X-up4
    AMD APU A8-6600K
    GIGAGYTE GAF2A88X-UP4
    8 GB DDR3-1866MKz
    Evga GTX 750ti
    Diamond sound blaster 5.1
    LG 23 inch LED,vga,dvi,hdmi
    1920x1080
    1000 TB
    Coolmax model zx- 600W
    Thermaltake mid-tower ATX
    performance cooling package heat sink,psu, video card
    microsoft wireless 5000
    Microsoft wireless 5000
    dsl 7-15m
    Installed (hot-swappable 3.5 HDD bays)
    ubuntu 14.04
    Windows 7 Pro
