Missing "My Documents"
4
Following a need to rest my Laptop(3 months old) to a factory reset after advice from Dell, My Documents "is missing" when opeining the icon nothing is present after viewing properties. Does anyone have any ideas on how to resolve.? Bill H.
Axon
Beacon of Happiness
Vista Pro
286
Location
Turnhout, BE
This should be in the General Discussion area.
And are you sure the Documents map wasn't linked to another map?
Right click on 'My Documents' -> Properties -> Location and is the location C:\Users\(your username)\My Documents?
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
Spd2Last
Pre-Engineer
Vista Pro
205
Location
Miami, FL
Hi Bill and welcome to the forums,
I do not fully understand what the problem is. Is the "Documents" folder missing (C:\Users\YourName\Documents), or is the folder itself empty?
    E6750 @ 3.2GHz
    Asus P5K-e/Wifi-AP
    4x1GB Crucial Ballistix DDR2 800
    PNY 8800GT @ 675/1675/950
    Asus Xonar DX
    Samsung SyncMaster 220WM
    500GB WD SATA II
    500GB Seagate SATA II
    700W OCZ GameXStream
    Cooler Master Centurion 5
    Arctic Cooling Freezer 7 Pro
    Logitech G5
    ~3Mb
Axon
Beacon of Happiness
Vista Pro
286
Location
Turnhout, BE
I think, when he tries to open it, a window comes up that My Documents is missing, e.g. like a shortcut that leads nowhere.
    ASUS P5B-E Plus
    ASUS EN8800GT 512
    1440x900 @ 75Hz
    Logitech G15 V1
    100.0 Mbps
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
4
Thanks for yor thoghts. However when following your idea on opening Prperties this leads to "General Tab" with no information against Location other than showing Zero Bytes
roy69
47,65,65,6B
2,607
Location
uk
When you said factory reset do you mean the hard drive was formatted before the restore was put back on? Check your pictures and music files to see if they are missing as well.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
4
#8
Hello Roy69.
Thanks for your response. Following advice from Dell all my info (Docs, Pictures etc)was backed up to a free standing hard drive.The reset then took place. The problem now comes in transferring back again as there is a "Dcuments" tab on the start up menu. However as when you normally right click you would then see open with other options, I do not; all there is, is copy rename and properties. To access my info I open the free standing hard drive to see all my info listed.A long winded process to say the least.I am not aware that any reformatting took place. My Pictures was in a totally separate file and trd back and opens without any difficulty.
Bill H.
roy69
47,65,65,6B
2,607
Location
uk
#9
You can manually copy the files back or keep them where they are.
If you copy them back then you will have a permanent backup which is not a bad thing.
If you leave them where they are and decide to use the backup drive for your documents then that is not bad either as the drive will be ok if you reformat. That is if it is an external HD.
If it is not an external HD I would backup all your documents to CD, DVD. If you need to make any changed to the documents stored on DVD you can copy them back to your documents and you will have an archive of the older version on your DVD. It depends on how much space you have and how often you change the documents.
Another option is to redirect vista to it thinks your personal folders are in the Backup Drive. Look here on how to do it
http://www.vistax64.com/tutorials/107990-personal-user-shell-folders-move-location.html?filter[11]=File%20Folder%20Settings
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
4
#10
'ello again roy69.
Your sound thoughts are appreciated. My intention and ideal preference is to have the back up on the free standing Toshiba hard drive and also to be able to acess my documents having opened the file on my computer. However when right clicking on the Documents tab in the start up menu there is no option for Open, only copy rename and properties. When opening properties no information as location file size etc is available. If I do go for the option to Transfer back to the folder how.
1.Do I open the folder bearing in mind what I have said earlier?
2.Havinging opened the Toshiba drive where do I send the various folders.
BillH
roy69
47,65,65,6B
2,607
Location
uk
#11
The reason you can not open the folder from your documents is becuase they are not there.
How was the backup performed?
Is the toshiba drive the backup?
Is it compressed(i.e. a zip or other format).
Can you open and view the files on the toshiba using My computer/drive letter/directory.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
#12
Bill,
Have you checked yet using Option Two in this tutorial, to make sure that your Documents (named Personal in registry) folder has the default location %USERPROFILE%\Documents set for it?
Personal User Folder - Restore Missing Folder
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
4
#13
Hello roy69.
Yes I do realise the Docs file is is empty when I right click the Icon as mentioned.
Back up was simply performed in the normal back up manner to the free standing Toshiba drive (ie outside my Laptop)The files remain there and fully visible and the file is not compressed.
Bill H.
roy69
47,65,65,6B
2,607
Location
uk
#14
You have two viable options.
1. You can open both folders in separate windows. Toshiba in one window and the empty My Documents in another window. Then drag and drop all the files, this will create a copy leaving the backup files.
2. Redirect the link as I discribed earlier in the tutorials section to the external HD. The only problem you may have with using this option, is if you remove the external HD then you will not have access to it if you remove the drive. (Another box to lug around).
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
