ML-1610 Samsung printer
spectrumvoid
Hi all.
Is there anywhere I can get the printer drivers for Samsung printer ML-1610? I'm running a X64 Vista system. The one's on the Samsung website do not work.
Thanks!
zigzag3143
Banned
Hi all.
Thanks!
Spectrum
i cant find a driver newer than 2004. what driver have you used in a Previous OS?
there are 32bit drivers but not 64
\en
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
zigzag3143
Banned
In my earlier XP OS, I just used the driver that came with the CD, but it doesn't work with Vista.
Best bet is if you can find a vista driver. If you cant you can install the XP driver in compatibily mode. to do that just right click the setup file and go to properties>then compatibility
Hope this helps
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
