Monitor too bright
25
Location
canada
Hi Guys
My monitor is too bright on the eyes, since my monitor is not hooked up analog
i don't have the option to lower brightness directly on panel settings.
Sometime ago (not sure how i did it, can't remember) i had changed the internet webpages background to grey(easier on the eyes).
Any help would be appreciated:)
    DualCore Intel E6300, 1866 MHz (7 x 267)
    Asus P5LD2
    2558MB
    ATI Radeon X550 (RV370) 3D Accelerator
    EnVision G218a1
    1680 x 1050
    Drive #1 - Maxtor 6E040L0 (38 GB)
    Drive #2 - Maxtor 6E040L0 (38 GB)
    black
    HID-compliant mouse
    HID Keyboard Device
Everlong
To xor or not to xor
1,317
Location
Lancaster University, England.
Why would not having it hooked up by analogue make a difference? Mine's hooked up with DVI and has the monitor control panel to adjust brightness.
I don't have an ATI card, but in the Nvidia control panel for me there's options to adjust screen brightness, so there's more than likely going to be the same option in the Catalyst Control Centre.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Steve,
You should be able to do this through your graphic adapter's control panel.
This is for NVidia, which is what I use. As for ATI, I am not sure of the exact screen, but it should be similar.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Steve,
I have just had a look at the User Manual for your monitor. In the section OSD Functions, under Color Adjust, do you have it set as sRGB as with this setting the Contrast and Brightness adjustments are disabled?
    Gigabyte IF233
25
Location
canada
DVI won't give me the option to adjust brightness. It's there but greyed out(can't choose it)
    Asus P5LD2
    2558MB
    EnVision G218a1
    1680 x 1050
    black
    HID-compliant mouse
    HID Keyboard Device
25
Location
canada
Thanks for all the help guys, i managed to lower the brightness with ATI Catalyst Control Centre , didn't know i even had it:geek:
    Asus P5LD2
    2558MB
    EnVision G218a1
    1680 x 1050
    black
    HID-compliant mouse
    HID Keyboard Device
Everlong
1,317
Location
Ahh that's odd. Atleast you got it sorted from the CCC :)
    ASUS Xonar DX
    100Mbps
