Solved Monitor Troubles after deleting Hibernation files
I deleted my hibernation file to save disk space but forgot to disable hibernation. Now my monitor comes on for about 2 seconds and then turns off. I can get the screen back (for 2-3 secs at a time) by turning off the monitor and turning it back on. A second monitor exhibits the same type of behavior. I think I messed up the video by hibernating. Can I recover from this?
    Dell Deminsion E520
    8MB
Try a System Restore to before you did this?
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
Try booting to the Advanced Boot Options menu: http://www.vistax64.com/tutorials/123496-safe-mode.html
Once there, select Last known good configuration, see if that works.
If not, boot to the menu again and select Enable low resolution video (640 x 480), see if that works.
If yes, once it finishes booting (it will look ugly), uninstall the Video card from Device Manger, then reboot.
Windows will rediscover the video and reload the drivers. See if that helps.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
Thank you Ztruker. The advice helped and I'm back up and running. Lesson learned: read the warnings before deleting files you don't know about.
    Dell Deminsion E520
    8MB
That's good to hear. Glad it's working now.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
