Monitor won't wake from Sleep Mode
radamo
I have tried several different settings and cannot get my monitor to wake up after sleeping for several hours. I have tried hybrid on and off. I have changed various settings in BIOS. I have made sure USB never turns off. I have changed the settings related to PCIe in sleep mode... Nothing works. I have a ABIT IP35Pro Board with an Sapphire 3850 Video card.
Any help would be appreciated.
RA
roy69
47,65,65,6B
Have you tried moving the mouse.
Have you tried turning the monitor off then on.
Is it on the same bit of software.
List your total spec and what software you are running.
Try running in safe mode to see if that changes the problem.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
radamo
Yes, I have moved the mouse, as well as clicking a button or two...
Have tried all monitor buttons including power...
The PC awakens... I can see hard drive activity etc...
It is just the video that is dead.
I have the following:
Q6600
Abit IP35 Pro
Planar PL2011M
4 GB of AData RAM
Sapphire 3850
Asus DVD RW 20X Drive
2 Seagate 500Gig Drives
Only software running was Firefox (latest 2.x version)
Thanks for the reply....
RA
coolchris
NoNonsense
Vista Pro
Check you leads at the back of the pc to make sure they aint loose. Reseat the graphics card. Update to latest graphics card drivers. Get the latest bios for you motherboard from Abit.
Also make sure you have all the latest microsoft updates..this rings a bell and I think that ms had a fix ages ago for this.
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
radamo
All leads are secure...
Latest Mobo bios...
Latest video, audio and chipset drivers...
Looking around it seems quite a few people are having the same issue. Maybe SP1 will address...
Thanks,
RA
talon191
I had the same issue I think it has to do with the Bios on the IP-35.
Heres some posts of people experiencing the same problem:
AnandTech - Abit IP35-E board with bios update 14, does not POST on first try?
IP35-E Bios Troubles - Help Please - Universal abit USA Forums
http://forums.hexus.net/abit-care-hexus/125947-how-i-update-my-bios.html
Updating to Bios version 14 should fix everything what Bios version did you upgrade to? Im still waiting to flash my bios I have to wait for some newegg parts.
If you cant get it to work I basically found out how to avoid the freeze alltogether if you want to try:
-I find thumping the computer case once not too soft but not too hard will jumpstart my motherboard almost everytime. I turn my mouse on its back to see the light and I'll thump the side of my case and usually after about 20 seconds or after 2 or 3 thumps the mouse red light on the bottom of the mouse will come on at which point gives me the signal to reset the computer then it starts fine usually.
-Try keeping a program running in the background (like bittorent) it tends to freeze more if the computer has been idle or shut off for a while I keep one bittorent file that is 9 gigs long but only downloads at 1 kb and my computer rarley freezes now.
Either way let me know if you find a permanent fix for this.
radamo
I am already at BIOS version 14. The computer wakes from sleep. I see the drive activity and hear the drives spin up etc... It is just the monitor that won't wake. I think that Vista has caused the mobo to kill the PCIe slot.. Or maybe a mobo bios update would cure it... Not really sure. For now I have the sleep mode disabled completely.
RA
