MotherBoard Question.
if it really is that broken, you can send it in to the manufacturer for repairs (it will cost you a fair bit) or you can just buy a new one and take some of the parts out of the old one for other things (buying an enclosure for the hard drive will give you an external hard drive, you can use the ram for another laptop, take the wifi out and integrate it into a desktop) but that's about it really.
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array 3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
