Mouse driver help?
Maranara
On saturday I called hp tech support to get a new mouse and they wanted to make sure my mouse wasn't working and my computer was fine. The tech support guy had me do a ton of stuff and I think I uninstalled my mouse driver and now with the new mouse, it won't work. My USB mouse works though.
How can I get the sp/2 mouse driver back?
AstaLaVista
Lost in Cyberspace
Vista Pro
So, you have a USB mouse that works and also a PS2-Type mouse that doesn't? is that correct?
If that is correct, the only thing that I can think of is:
1.- you have plugged the PS2 mouse in the incorrect slot (where the keyboard has to be)
2.- Somehow, you have inserted the PS2 in the correct slot but inverted so it is there but not fully functioning?
3.- Disabled PS2 type mouse in your bios
Things I would try:
Turn off Computer, disconnect your USB & PS2 mouse, Start your PC and get into the Bios, find out if your PS2 port is Open (Enable) or Close (Disable), if the latter, Open it (Enable it). If you can't find anything in the Bios, save on Exit and turn computer off again. Unplug the power cord.
Plug in your PS2-Type mouse in the correct PS2 port, making sure it is inserted correctly, plug in your power cord and start your pc and let it get in into the desktop, if you have a problem at login screen, try to get to the desktop using your keyboard, wait a while as it may be installing the driver for it.
Let us know what happens
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
AstaLaVista
Lost in Cyberspace
Vista Pro
Glad to hear it.
    EVGA GTX260
    1680 x 1050
    Samsung Sata 750GB
    Logitech G7
    Logitech G15
