Moving a hard drive with partitions
Everlong
To xor or not to xor
Just wanting to clarify something:
If I have a hard drive in my PC, and have partitioned it and then I want to move this hard drive on to a new computer, will the partitions stay or will I need to re-partition the hard drive in the new PC?
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
I believe the partitions will stay like they were before the move.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
That's what I was thinking, thanks a lot :)
    ASUS Xonar DX
    100Mbps
Your welcome Everlong18
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Hello Everlong.
I just did exactly that, I partitioned and formatted a HDD in the old HP system using Vista and then moved a bunch of "stuff" to one of the partitions and then moved the HDD to the new build and installed Vista 64-bit to it and I didn't even have permission problems with it.
Moving an OS will probably cause problems though!
Later ;) Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Yea I know I'll have to reinstall the OS, just I have partitioned this hard drive for music/movies/pictures and just want them to stay on it, thanks Ted :)
    ASUS Xonar DX
    100Mbps
Yeah, I have done this multiple times as well. Because all the partition and info is kept on the HDD, then you could move it to anything and keep all that info! Nice isn't it? Besides, think of all the problems with flash drives and portable HDD's if it didnt!!!!
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Tarantula
    Razer Lachesis
    not fast enough
Yea I was pretty sure all the information was kept on the hard drive, but I was also thinking that possibly it's all kept on the computer you made the partition on, so moving computers would mess the partitions up, but thanks for further clarifying it :)
    ASUS Xonar DX
    100Mbps
No prob.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Tarantula
    Razer Lachesis
    not fast enough
