Solved MS Word.. My saved document becomes default template
sirivarin
I'm using MS word 2007 on Vista. Months ago, I made a document then saved and later then whenever I open MS Word, it appears "that document" as a template. How can I erase that document and go back to a blank .doc page?
    SONY VAIO VGN-CR35S/P
    Intel(R) Core(TM)2 Duo T8100 @2.1GHz
    2.00GB
garysgold
Hello sirivarin,
Welcome to the forums.
Only thing I can think to cause this is that you inadvertently saved the file with the .dotx extension. If you need to keep the file, open it and save as a .docx file, then delete the file with the dotx extension.
Please keep us posted.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
garysgold
Glad to hear you got it sorted out, sirivarin.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
