With MS Works if I try to copy and paste from an online forum I get the message “Internet explorer has stopped working etc” and it just will not do it whereas if I use MS Word there is no problem at all, is it fixable?
The problem may be that browsers update but MS Works doesn't therefore you will receive some incompatibility issues.
Has this always happened? What was the earliest version of IE that you tried? IE 7 was the latest I believe to be around before MS works was discontinued.
MS Office Home & Student replaced MS works however they have even removed that recently to change for Office 365 which is a subscription based word processor. Unfortunately it is not compatible with Windows Vista therefore to be able to use Office you will need to upgrade to Windows 7 or 8
A possible alternative could be LibreOffice which is an free open office solution offering the choice to save documents in Word 2003 format - Home » LibreOffice
Thanks Josh, I have d/l Libre Office but when I go to install I find I cannot "run as administrator" which is a bit of a worry as I always do a custom install to eliminate add ons that I don't want the only option I have is "Install" any advice? (what I mean is are there any fish hooks)
My PC is 5 years old so what ever IE was around at that time was my earliest version.
Can't supply screen shot as menu whites out when snip tool clicked, but I suppose I can do a restore if it does have unwanted add ons, I will try and see what happens.
