Multiple Vista Failures
jaff
Greetings:
I am running Vista Home Premium 32 bit without service pack 1 and have been trying to download windows updates for about a month now.
I get a Windows Update error message 8007000b
I ran the command prompt as administrator,typed in fsutil resource setautoreset true C:\.
and I got a message saying
“The file or directory is corrupted and unreadable”
I have tried to download updates 1 at a time, turned off my anti virus And tried manual updates
My Error checking is not working “windows can’t check the disk while it’s in use”
And schedule disk check does not work
The System File Checker tool gives the message
“windows resource protection found corrupt files but was unable to fix some of them”
The windows memory diagnostic tool runs, reboots and does not display any results
Would appreciate any ideas on how and where to start
Thanks
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
jaff
Hi Jaff,
See if you can run chkdsk /f in Option Three of Method Two in this tutorial.
http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
Afterwards, restart the computer to see if you can run Windows Update.
Thanks for your response Shawn:
Typing in chkdsk c: /f in command prompt from system recovery options
Gives this response:
The type of the file system is NTFS
Chkdsk cannot run because the volume is in use…
Chkdsk may run if this volume is dismounted first
All opened handles to this volume would then be invalid
Would you like to force dismount on this volume?
I’m not sure I like the sound of that. Although typing in chkdsk c: does start a slow check and shows corrupt areas.
jaff
joel406
Senior Member
Sorry to tell you but it looks like a bad hard drive.
The only thing left for "you" to do now is to try a clean install of Vista. And if that fails you more then likly have a bad hard drive.
Then you can get a new one from your OEM(if your still under waranty. Or your next option is to get one from www.newegg.com or local at a Best Buy.
You can also download and create a Hirens diagnostic disk. You can find it with a google searh and all the insructions are at the site for creation and use.
A scan with a Hirens disk will find out for sure if your HD is good or not.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA
    1 250GB Western Digital SATA
    1 200GB Maxtor SATA
    2x160GB Western Digitals SATA
    1 320GB Seagate External
    1 120GB Western Digital External
    1 80GB Westen Digital External
    1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
jaff
I have a second hard drive on my machine . Would I be able to install vista on it and run both so I can transfer files and duplicate my setup (gradually)?
Or will my OEM Vista not allow it and see it as a second computer?
Thanks
jaff
Brink
Staff member
mvp
Hi Jaff,
jaff
Jaff,
Answer Y to the dismount question to let chkdsk run.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
SCSIraidGURU
I would run chkdsk c:/r and let it do it on a restart. /r invoke /f and a few other tests.
    16GB DDR667
    SAS RAID
jaff
Chkdsc c: /f worked after a number of tries without requesting a dismount.
Windows update is working and I am up to date except for service pack 1.
Many Thanks to All
Jaff :)
Brink
Staff member
mvp
Jaff I'm glad to hear that you got it sorted out. Thank you for the feedback.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
