Must be logged in as Administrator to use simplecenter?
Nes
Hey
I downloaded a program called simplecenter,so i can gain excess to my pc through my ps3,but it says i have to log in as an administrator..
I have done everything you have said in your posts on page 1 and it worked,i have a new user called administrator..
My questions is :
Cant i use this program when logged in on my other user??
Do i have to be logged in as the administrator everytime to use this program or is it only when i install it????
Hope you can help :)
richc46
Staff member
The program itself makes that decision, it was written to be used only by an adminstrator or a standard user can use it, also
You can try to right click on the program icon (not short cut) and then run as adminstrator, that usually works.
