My computer keeps freezing
11
Ok, my computer is fairly new, about 2 1/2 weeks old. And past week or so, I been experiencing random and sudden freezing. The first time it happened was when I was playing BF2. Another time when it happened was when I was browsing the web and listen to iTunes. So far, my computer froze about 6 times. I know it froze because there is a repeating sound of either my game or the songs. And also the Num Lock light won't turn off or on and the mouse pointer is frozen. Hodling CTRL+ALT+Delete does not respond.
Just now, while browsing this forum using the key "Page Down", it froze. It's like any sudden movement will freeze my computer.
My computer is HP m8430f. Specs are
Quad 6600
4MB Ram
Windows Vista SP1 64 bits
t3m0
Performance Lover
20
Location
Merced
are you up to date with current drivers and updates? and what anti-virus program(s) do you have because they might not be compatible. I had a similar problem not too long ago.
  • Monitor(s) Displays
    61" Panasonic 1080 HDTV
    500w
    First Build
1,823
What are your specs and your power supply specs? Do you have a multimeter? If yes, check your 12V voltage. It could be your power supply 12V rails are too small for your hardware.
    16GB DDR667
    SAS RAID
1,823
Verify your power supply. I have seen power supplies cause gaming issues with lacking enough 12V current to power a graphics adapter and CPU for gaming.
    16GB DDR667
    SAS RAID
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Random freezing can indicate a hardware fault. However, since your PC is fairly new, you need to exercise your warranty. DO NOT open your PC as you could invalidate your warranty.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
1,823
He is correct. Call for support. They can replace components under warrenty.
    16GB DDR667
    SAS RAID
75
#8
Quad 6600
4MB Ram
I still have random freezes. It's not as bad as when I first had x64 installed, but I don't have full confidence (to say the least) in Vista x64.
    E6850 3.0GHz
    EVGA 790i Ultra
    2x2Gb (4GB) OCZ3P13334GK
    EVGA 8800GTS 512MB KO
    WD 150GB Raptor
11
#9
OK this is what I got around the time it froze. Any ideas?
Problem signature
Problem Event Name: BEX64
Application Name: svchost.exe
Application Version: 6.0.6001.18000
Application Timestamp: 47919291
Fault Module Name: StackHash_951b
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0000000000000000
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 951b
Additional Information 2: 93ea6d2702c8e82a53bdc5dcd744c011
Additional Information 3: 0766
Additional Information 4: f928f1d359523eef78c34d7ae07dbde4
t3m0
Performance Lover
20
Location
Merced
#10
I googled BEX64 and it means a buffer overflow. buffer overflow can be an attack by a virus or trojan so try a virus scan. if that doesn't work, its a good idea to use your warranty and get them to fix it.
    500w
    First Build
