My enter key will not pop back up!
stoneys-nutz
Gamerholic
2,685
Location
Wale's
Hello Thatonedude,
Sounds like you need to clean it.
There are two ways of doing this.
1. Strip out the keypad, clean, and re-install.
2. Clean the keypad by using compressed air, and a spray cleaner.
If you choose option one, it's not that hard a job to do, just make a note of what goes where.
If you choose option two, your local PC shop will have all the bits you need to get this done.
Hope this helps, good luck.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
